Hue Secure Contact sensor not showing up
nitpicker
Domoticz version: 2022.2
Post by nitpicker »
I have bought the new Hue Secure Contact sensor (door/window sensor), but it isn't showing up in Domoticz. A new motion sensor showed up immediately.
Is the Hue contact not supported? Or do I have to change a setting or something.
Domoticz version: 2024.7
Re: Hue Secure Contact sensor not showing up
With what integration in Domoticz are you working? Hue Bridge, Zigbee2MQTT, Zigbee4Domoticz Plugin, Conbee/Deconz?
nitpicker
Post by nitpicker »
I use the Hue bridge and all other things work flawless. Lights and motion sensors (also newly added ones).
There has been no functional changes to Philips Hue bridge the last years so probably not implemented yet. If you do not have C++ programming skills then you have to wait until someone with a Hue bridge and this sensor and programming skills has the same issue.
nitpicker
Post by nitpicker »
Too bad I'v no C++ programming skills...
