Zigbee n00b issues. Pairing option Topic is solved
Rolandet
Domoticz version: 2021.1
Post by Rolandet »
hi all,
I've installed Zigbee2MQTT based on Stas' git repo
I've also tried to follow instructions on several (older) youtube video's.
What I saw is that after adding the hardware in Domoticz, I should have an option 'Zigbee pairing'
However, that option is not presented.
Am I missing something? or could this be versioning differences?
The only thing under devices that showed up is "Zigbee2mQtt api_transport 255 Zigbee2MQTT API Transport
Eventhough that was instructed, Im not sure how to continue now.
Any idea's?
tnx
Custodes Septentrionum
Domoticz version: 2025.1
Re: Zigbee n00b issues. Pairing option
If you are new to Domoticz and zigbee you better start using the mqtt auto discover option instead of the python plugin.
See the wiki
https://www.domoticz.com/wiki/Zigbee2MQTT
Rolandet
Post by Rolandet »
waltervl wrote: Monday 11 September 2023 23:58 If you are new to Domoticz and zigbee you better start using the mqtt auto discover option instead of the python plugin.
See the wiki
Thanx, I've had a previous setup, but that didn't work anymore, so I thought I'd start over.
I've followed the nstructions for Autodiscovery, however I don't seem to have the /opt/zigbee2mqtt directory :(
If Zigbee2MQTT is already running you do not need to do anything in Domoticz with /opt/Zigbee2MQTT directory. So I don't understand where your remark is coming from.
Edit, I see now you have to edit the configuration of Zigbee2MQTT. You can also do that from the user interface of Zigbee2MQTT
Rolandet
Post by Rolandet »
waltervl wrote: Tuesday 12 September 2023 21:57 If Zigbee2MQTT is already running you do not need to do anything in Domoticz with /opt/Zigbee2MQTT directory. So I don't understand where your remark is coming from.
I see. Unfortunately the interface is not available either.
So, both the python plugin as well as the auto discovery mode aren't working for me
I do have to admit that I've bypassed the Docker imagery and installed straight on the pi. Could that be an issue?
Yes, you have to find it somewhere else on your system. Start with the Zigbee2MQTT folder in your home.
Dave21w
Domoticz version: Stable
Post by Dave21w »
try using this
systemctl status zigbee2mqtt.service
from command line to see if it's actually running, z2m won't start if it cannot detect the coordinator so have you edited the .yaml with the correct values?
I wonder how you installed it on your Pi. Did you use this instruction: https://www.zigbee2mqtt.io/guide/instal ... installing
Rolandet
Post by Rolandet »
Dave21w wrote: Wednesday 13 September 2023 8:53 try using this
ok, this says up and running
 zigbee2mqtt.service - zigbee2mqtt
   Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
   Active: active (running) since Wed 2023-09-13 17:44:11 CEST; 562ms ago
 Main PID: 6255 (node)
    Tasks: 6 (limit: 3860)
   CGroup: /system.slice/zigbee2mqtt.service
           └─6255 node /usr/bin/npm start
Rolandet
Post by Rolandet »
waltervl wrote: Wednesday 13 September 2023 9:06 I wonder how you installed it on your Pi. Did you use this instruction: https://www.zigbee2mqtt.io/guide/instal ... installing
I tried that (again) but it fails at NPM.
But (see comment above) zigbee2mqtt does seem to run now
Rolandet
Post by Rolandet »
Eventhough it says up-and-running, my devices are nowhere to be seen :?
