Dashticz garbage no results for Omrin
droepie
Post by droepie »
For some time now it looks like Omrin in the garbage-module isn't working anymore. It says: 'Geen gegevens beschikbaar' But when I use thier own API I do get a result. Furthermore I notice that in the garbage-module https://www.omrin.nl/bij-mij-thuis/afva ... alkalender is used where as they (Omrin) use https://um-omrin-prod.tresprojecten.nl/ ... alkalender
You can use 9255 JD (zipcode) with number 36. Don't you worry. The house is empty and for sale for some time now
Lokonli
Re: Dashticz garbage no results for Omrin
Post by Lokonli »
Try 'afvalinfo' as provider, like:
blocks['omrin'] = { title: 'Omrin', company:'afvalinfo', zipcode: '9255JD', housenumber: '36' }
Available since Dashticz 3.10.3 beta.
droepie
Post by droepie »
This is in my config:
blocks['mygarbage'] = {
company: 'omrin',
zipcode: '9255JD',
street: 'Toutenburgleane',
housenumber: 36,
maxitems: 12,
width: 12
HansieNL
Post by HansieNL »
Can you try with
company: 'afvalinfo',
zipcode: '9255JD',
housenumber: 36,
maxitems: 12,
width: 12
Blah blah blah
droepie
Post by droepie »
Yes, that did the trick. Should I have known that, because it used to work with 'Omrin' according to the docs.
But thanks!
