For some time now it looks like Omrin in the garbage-module isn't working anymore. It says: 'Geen gegevens beschikbaar' But when I use thier own API I do get a result. Furthermore I notice that in the garbage-module https://www.omrin.nl/bij-mij-thuis/afva ... alkalender is used where as they (Omrin) use https://um-omrin-prod.tresprojecten.nl/ ... alkalender
You can use 9255 JD (zipcode) with number 36. Don't you worry. The house is empty and for sale for some time now
Dashticz garbage no results for Omrin
Lokonli
Re: Dashticz garbage no results for Omrin
Try 'afvalinfo' as provider, like:
Available since Dashticz 3.10.3 beta.
blocks['omrin'] = { title: 'Omrin', company:'afvalinfo', zipcode: '9255JD', housenumber: '36' }
droepie
This is in my config:
blocks['mygarbage'] = {
company: 'omrin',
zipcode: '9255JD',
street: 'Toutenburgleane',
housenumber: 36,
maxitems: 12,
width: 12
company: 'omrin',
zipcode: '9255JD',
housenumber: 36,
maxitems: 12,
width: 12
- HansieNL
Can you try with
company: 'afvalinfo',
zipcode: '9255JD',
housenumber: 36,
maxitems: 12,
width: 12
Blah blah blah
droepie
Yes, that did the trick. Should I have known that, because it used to work with 'Omrin' according to the docs.
But thanks!
But thanks!
