HomeHabit dashboard app now also for IOS Topic is solved
Domoticz version: 2025.1
The creator of the HomeHabit dashboard app is working on the IOS version with from version 0.5 the Domoticz integration!
It is still in test fase . It is an ideal app if you want to turn your tablet into a Domoticz control system.
For more info check the HomeHabit forum: https://community.homehabit.app/t/homeh ... w-0-5/3147
MikeF
Domoticz version: V2022.2
Re: HomeHabit dashboard app now also for IOS
Post by MikeF »
I'm quite excited about this! :)
I currently have 3 HomeHabit dashboards on a Samsung Android tablet, all from Domoticz. I've managed to partly replicate one of these on my iPad (work in progress), and I look forward to the inclusion of temperature and custom / text widgets.
Android version:
iOS version:
I use it on my Android tablet too, very happy with this.
Another example (on Android):
igor
Post by igor »
waltervl wrote: Wednesday 17 May 2023 0:17 The creator of the HomeHabit dashboard app is working on the IOS version with from version 0.5 the Domoticz integration!
Thank you for sharing it with the community!
MikeF wrote: Wednesday 17 May 2023 11:29 I'm quite excited about this! :)
It is very exciting for me as well! iOS version has been a long time coming.
HomeHabit iOS Preview 0.7 now includes Number and Text widgets. Number widget doesn't support some temperature/humidity devices yet, depending on device type/subtype, but more will be added soon. If you have specific devices that are not supported yet, post type/subtype for those, so it can be prioritized.
MikeF
Post by MikeF »
Hello Igor,
I have temperature devices of the following types / subtypes in Domoticz:
These work well in the Android version.
Mike
@Igor: a warning for your app as Domoticz API has changed in latest beta 15326 (1-jun-2023) https://www.domoticz.com/wiki/Domoticz_ ... d_newer.29
igor
Post by igor »
MikeF wrote: Friday 02 June 2023 12:09 I have temperature devices of the following types / subtypes in Domoticz:
These will be added in the next release.
waltervl wrote: Monday 05 June 2023 15:43 @Igor: a warning for your app as Domoticz API has changed in latest beta 15326 (1-jun-2023) https://www.domoticz.com/wiki/Domoticz_ ... d_newer.29
Thanks for the heads up!
The list of backward compatible API commands is extended:
