The creator of the HomeHabit dashboard app is working on the IOS version with from version 0.5 the Domoticz integration!
It is still in test fase . It is an ideal app if you want to turn your tablet into a Domoticz control system.
For more info check the HomeHabit forum: https://community.homehabit.app/t/homeh ... w-0-5/3147
HomeHabit dashboard app now also for IOS Topic is solved
- Domoticz version: 2026.3
MikeF
- Domoticz version: V2022.2
Re: HomeHabit dashboard app now also for IOS
I'm quite excited about this!
I currently have 3 HomeHabit dashboards on a Samsung Android tablet, all from Domoticz. I've managed to partly replicate one of these on my iPad (work in progress), and I look forward to the inclusion of temperature and custom / text widgets.
Android version:
iOS version:
Android version:
iOS version:
I use it on my Android tablet too, very happy with this.
Another example (on Android):
Thank you for sharing it with the community!waltervl wrote: Wednesday 17 May 2023 0:17 The creator of the HomeHabit dashboard app is working on the IOS version with from version 0.5 the Domoticz integration!
It is very exciting for me as well! iOS version has been a long time coming.MikeF wrote: Wednesday 17 May 2023 11:29 I'm quite excited about this!![]()
HomeHabit iOS Preview 0.7 now includes Number and Text widgets. Number widget doesn't support some temperature/humidity devices yet, depending on device type/subtype, but more will be added soon. If you have specific devices that are not supported yet, post type/subtype for those, so it can be prioritized.
MikeF
Hello Igor,
I have temperature devices of the following types / subtypes in Domoticz:
These work well in the Android version.
Mike
Mike
@Igor: a warning for your app as Domoticz API has changed in latest beta 15326 (1-jun-2023) https://www.domoticz.com/wiki/Domoticz_ ... d_newer.29
These will be added in the next release.MikeF wrote: Friday 02 June 2023 12:09 I have temperature devices of the following types / subtypes in Domoticz:
Thanks for the heads up!waltervl wrote: Monday 05 June 2023 15:43 @Igor: a warning for your app as Domoticz API has changed in latest beta 15326 (1-jun-2023) https://www.domoticz.com/wiki/Domoticz_ ... d_newer.29
The list of backward compatible API commands is extended:
