This looks interesting… a true presence monitor with Wi-Fi connection.
https://youtu.be/yarollsdao4
Aquara FP2
Scotty
Re: Aquara FP2
Has anyone integrated this with domoticz? I’ve just purchased one but didn’t even consider that it’s not yet supported
- Domoticz version: 2025.1
Re: Aquara FP2
Seems to be only connecting to outside world with Homekit. Perhaps this is an option to get it into Domoticz. Use the Homebridge integration for this. As I do not have this I cant help you further.
aardwolf2
Re: Aquara FP2
I have this working. I tried the homebridge integration but as far as I could tell this only allows ingest of Domoticz devices into Homekit, I couldn't find a way to feed a homekit device into Domoticz. So.......I set up a H*me Assistant VM, used the built in Homekit integration in HA to get the FP2 into that, then used MQTT to get the values out of HA into Domoticz. Never let a lack of talent stop you from bodging things
Now to find a lightweight homekit - MQTT bridge, HA is a big old boy.
- habahabahaba
- Domoticz version: 2024.4
Re: Aquara FP2
If it uses mqtt may be this will be helpfull?
aardwolf2
Re: Aquara FP2
Thanks fo the info, but I'm only using MQTT as an easy way to get the status out of HA, it's the reliance on HA I'm trying to avoid, so I need something to emulate a homekit controler to pair the FP2 with. I managed to find the github project that HA uses for it's Homekit controller, and have promptly lost it. If I find it again and get something working I'll update.....but as it works now, and a reboot has made HA a bit less bloaty on the server, you never know.
