Aquara FP2
nigels0
Domoticz version: 3.8153
Aquara FP2
Post by nigels0 »
This looks interesting… a true presence monitor with Wi-Fi connection.
https://youtu.be/yarollsdao4
Scotty
Re: Aquara FP2
Post by Scotty »
Has anyone integrated this with domoticz? I’ve just purchased one but didn’t even consider that it’s not yet supported :shock: :shock:
Domoticz version: 2025.1
Re: Aquara FP2
Seems to be only connecting to outside world with Homekit. Perhaps this is an option to get it into Domoticz. Use the Homebridge integration for this. As I do not have this I cant help you further.
aardwolf2
Re: Aquara FP2
Post by aardwolf2 »
I have this working. I tried the homebridge integration but as far as I could tell this only allows ingest of Domoticz devices into Homekit, I couldn't find a way to feed a homekit device into Domoticz. So.......I set up a H*me Assistant VM, used the built in Homekit integration in HA to get the FP2 into that, then used MQTT to get the values out of HA into Domoticz. Never let a lack of talent stop you from bodging things :lol: Now to find a lightweight homekit - MQTT bridge, HA is a big old boy.
habahabahaba
Domoticz version: 2024.4
Re: Aquara FP2
Post by habahabahaba »
If it uses mqtt may be this will be helpfull?
aardwolf2
Re: Aquara FP2
Post by aardwolf2 »
Thanks fo the info, but I'm only using MQTT as an easy way to get the status out of HA, it's the reliance on HA I'm trying to avoid, so I need something to emulate a homekit controler to pair the FP2 with. I managed to find the github project that HA uses for it's Homekit controller, and have promptly lost it. If I find it again and get something working I'll update.....but as it works now, and a reboot has made HA a bit less bloaty on the server, you never know.
