Import data from tasmota into domoticz
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi, I am having a number of powerplugs flashed with tasmota. Important data is sent to Domoticz via MQTT. That is OK. But Tasnota generates more interesting data. See down below. Now I wonder what is syntax to sent data such as e.g. cos.phi which below is named "factor".
Any suggestion? May feelings tell me to use rules but realy don't know how to.
Bart
10:40:39.159 MQT: tele/tasmota_CBD979/SENSOR = {"Time":"2023-04-02T21:40:39","ENERGY":{"TotalStartTime":"2023-03-22T17:49:17","Total":12.994,"Yesterday":0.853,"Today":3.959,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":238,"Current":0.000}}
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Re: Import data from tasmota into domoticz
How do you connect your tasmota devices now with Domoticz? You could try to extend that functionality.
Else you could try Tasmota rules and have it send a proper Domoticz/in MQTT message or a Domoticz http(s) API call. Examples are in the tasmota documentation (search for domoticz). You perhaps have to manually make a Domoticz virtual sensor to receive the data.
Or if using MQTT you could use the MQTTMapper python plugin to map MQTT message to Domoticz device: viewtopic.php?t=39279
