Dear All,
I have the ZigBeeForDomoticZ plugin (Firmware: Zigate - 0321 / Plugin: 6 3 011) on a Raspberry Pi and after an update, there is no trashcan in fornt of the device in devicemanagement to remove a device. Now there's a status sign. And I need to remove three devices, because after my last powerfailure there not recognized anymore.
Thanks in advance.
ZigBeeForDomoticZ plugin can't remove devices Topic is solved
- Frumpie69
- Domoticz version: 2020.2
- Schermafbeelding 2023-03-17 184835.png (36.53 KiB) Viewed 715 times
Re: ZigBeeForDomoticZ plugin can't remove devices
you need to remove them from domoticz
- Frumpie69
I already did that. There gone in Domoticz. In group management you still can delete them with a trashcan. Earlier that was also possible with devices.
It was possible only if they were no remaining Widget left in Domoticz, otherwise you are creating inconsistency between Domoticz and the plugin and would have issues later
- Frumpie69
Thank you! I thought I deleted the devices, but I didn't. Great advice! It worked and now I try to add them again.
Have a great weekend!
