ZigBeeForDomoticZ plugin can't remove devices Topic is solved
Frumpie69
Post by Frumpie69 »
Dear All,
I have the ZigBeeForDomoticZ plugin (Firmware: Zigate - 0321 / Plugin: 6 3 011) on a Raspberry Pi and after an update, there is no trashcan in fornt of the device in devicemanagement to remove a device. Now there's a status sign. And I need to remove three devices, because after my last powerfailure there not recognized anymore.
Thanks in advance.
Schermafbeelding 2023-03-17 184835.png (36.53 KiB) Viewed 706 times
pipiche
Re: ZigBeeForDomoticZ plugin can't remove devices
Post by pipiche »
you need to remove them from domoticz
Frumpie69
Post by Frumpie69 »
I already did that. There gone in Domoticz. In group management you still can delete them with a trashcan. Earlier that was also possible with devices.
pipiche
Post by pipiche »
It was possible only if they were no remaining Widget left in Domoticz, otherwise you are creating inconsistency between Domoticz and the plugin and would have issues later
Frumpie69
Post by Frumpie69 »
Thank you! I thought I deleted the devices, but I didn't. Great advice! It worked and now I try to add them again.
Have a great weekend!
