Hi!
so i thought i make a clone of my sd card from my rpi, so i turned of the rpi and made a clone in my computer, now it seem like z-wave wont initialize any more, the settings in open z-wave usb are always red, and if i look in groups nothing happens, it wont mesh.
i tried the clone card as well and its the same problem.
im starting to panic here.
please help.
i run version 2022.2
sudden open z-wave problems
- Domoticz version: 2024.6
Re: sudden open z-wave problems
Try a reboot and pay attention to the node status updates in the OZW control panel. I would also check the USB settings of your stick, if you have inserted a USB device and Openzwave is not set to use /dev/serial/by-id .... then you may find problems if the Z-stick is now on a different path.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
