sudden open z-wave problems
tjabas
Post by tjabas »
Hi!
so i thought i make a clone of my sd card from my rpi, so i turned of the rpi and made a clone in my computer, now it seem like z-wave wont initialize any more, the settings in open z-wave usb are always red, and if i look in groups nothing happens, it wont mesh.
i tried the clone card as well and its the same problem.
im starting to panic here.
please help.
i run version 2022.2
solarboy
Domoticz version: 2024.6
Re: sudden open z-wave problems
Post by solarboy »
Try a reboot and pay attention to the node status updates in the OZW control panel. I would also check the USB settings of your stick, if you have inserted a USB device and Openzwave is not set to use /dev/serial/by-id .... then you may find problems if the Z-stick is now on a different path.
