Dashticz - v3.10 master
Lokonli
Post by Lokonli »
Dashticz v3.10 master just has been released.
It contains the changes made available in the beta branch since Dashticz v3.9, approximately 10 months ago.
List of enhancements:
  • Dials: Add colored ring to dimmers in on state (optionally to blinds as well)
  • Dials: Add ‘delay’ parameter to delay the updating of Up/Down percentage blinds.
  • Dials: For RGB switches you can open the color selector popup by adding switchMode: 'color' to the block definition.
  • Dials: Needle step size configurable via steps block parameter.
  • Dials: For wind device, add block parameter subtype: 'windspeed' to use wind speed for needle position instead of wind direction.
  • Dials: For wind device, add block parameter subtype: 'windgust' to use wind gust for needle position instead of wind direction.
  • Dials : Up/down dials for Thermostats, Blinds and Dimmers. See Up-down dials
  • Garbage: Added Maashorst (Uden, Volkel, Odiliapeel, Reek, Schaijk en Zeeland)
  • Public transport: New block parameter show_direction to show bus line direction.
  • Public transport: New block parameter lang to set language for search results (for irailbe only).
  • Public Transport: New block parameter direction to filter on line direction number. See Public Transport
  • Weather: Added ‘knmi’ as weather forecast provider.
  • Config: New config parameter ‘use_hidden’ to make use of Domoticz hidden devices as well.
List of fixes:
  • Fixes in autoswipe timeout computations
  • Swiper vertical scroll bar
  • Selector switches: Hide title in case parameter hide_title is true, title is 0 or title is ‘’
  • Switches: Fix textOn textOff block parameter for some switch types
  • Blinds: Fix Open/Close in new Domoticz version (build>14535)
  • Dials: Fix scaling parameter for computed values (NettUsage, NettCounterToday, NettCounter) for P1 Smart Meter
  • Dials: Slightly bigger default size of dial. Set block parameter scale: 0.9 to reduce the dial size.
  • Dials: Fix min, max setpoint setting in CONFIG.js
  • Dials: Translations for wind direction.
  • Dials: Added translations for the EvoHome controller
  • Graph: Remove total counter graph line for some dial types, only in case graphTypes and legend have not been defined.
  • Calendar: Fix for opening Outlook calendar files
  • Calendar: Fix styling for some events with customized styling
  • Calendar: Fix start date (method:2, layout:2)
  • Garbage: Fix for Circulus-Berkel
  • Garbage: Fix for Purmerend, Suez, Blink
  • Garbage: Uden (new URL, same as Maashorst)
  • Public transport: Translations
For more details see Dashticz 3.10 Release Notes, or the Dashticz documentation.
pvklink
Domoticz version: latest b
Re: Dashticz - v3.10 master
Post by pvklink »
I cant get my ov infor tram working again with beta 3.10.0
tried tpc instead of old station... still the same
//https://ovzoeker.nl/locatie/52.02809:4.31246:16
blocks['ovapi'] = {
//station: '5616', // 5615 is station er tegenover
//direction: '2', // toegevoegd omdat destination niet goed werkt, maar met een deel
//destination: 'Den Haag', //Den Haag Kunstmuseum werkt niet, Den Haag wel, maar direction is makkelijker
tpc: '5616',
title:'Tram',
show_lastupdate:true,
provider: 'ovapi',
show_via: false,
icon: 'fas fa-tram',
results: 30,
width: 12
keeps giving loading
Jablotron connection, Ikea
Lokonli
Post by Lokonli »
The SSL certificate of OVAPI expired :(
I've created a new release (v3.10.0.1) with a fix.
pvklink
Post by pvklink »
topper
pvklink
Post by pvklink »
werkt weer!
dank @lokonli
RLezer
Post by RLezer »
outlook calendar works like a charm ! thanks @lokonli
janportinga
Domoticz version: 2023-2
Re: Dashticz
Post by janportinga »
Is it also possible to add the municipality DFM to garbage?
