It contains the changes made available in the beta branch since Dashticz v3.9, approximately 10 months ago.
List of enhancements:
- Dials: Add colored ring to dimmers in on state (optionally to blinds as well)
- Dials: Add ‘delay’ parameter to delay the updating of Up/Down percentage blinds.
- Dials: For RGB switches you can open the color selector popup by adding switchMode: 'color' to the block definition.
- Dials: Needle step size configurable via steps block parameter.
- Dials: For wind device, add block parameter subtype: 'windspeed' to use wind speed for needle position instead of wind direction.
- Dials: For wind device, add block parameter subtype: 'windgust' to use wind gust for needle position instead of wind direction.
- Dials : Up/down dials for Thermostats, Blinds and Dimmers. See Up-down dials
- Garbage: Added Maashorst (Uden, Volkel, Odiliapeel, Reek, Schaijk en Zeeland)
- Public transport: New block parameter show_direction to show bus line direction.
- Public transport: New block parameter lang to set language for search results (for irailbe only).
- Public Transport: New block parameter direction to filter on line direction number. See Public Transport
- Weather: Added ‘knmi’ as weather forecast provider.
- Config: New config parameter ‘use_hidden’ to make use of Domoticz hidden devices as well.
- Fixes in autoswipe timeout computations
- Swiper vertical scroll bar
- Selector switches: Hide title in case parameter hide_title is true, title is 0 or title is ‘’
- Switches: Fix textOn textOff block parameter for some switch types
- Blinds: Fix Open/Close in new Domoticz version (build>14535)
- Dials: Fix scaling parameter for computed values (NettUsage, NettCounterToday, NettCounter) for P1 Smart Meter
- Dials: Slightly bigger default size of dial. Set block parameter scale: 0.9 to reduce the dial size.
- Dials: Fix min, max setpoint setting in CONFIG.js
- Dials: Translations for wind direction.
- Dials: Added translations for the EvoHome controller
- Graph: Remove total counter graph line for some dial types, only in case graphTypes and legend have not been defined.
- Calendar: Fix for opening Outlook calendar files
- Calendar: Fix styling for some events with customized styling
- Calendar: Fix start date (method:2, layout:2)
- Garbage: Fix for Circulus-Berkel
- Garbage: Fix for Purmerend, Suez, Blink
- Garbage: Uden (new URL, same as Maashorst)
- Public transport: Translations
