Hi Guys,
Lidl HG08164 TS004F Zigbee Manufacturer _TZ3000_rco1yzb1. It is paired using Zigbee 2Mqtt and The device shows up in Domoticz like all my other devices.
Difference is that this is a selector button, but it does not work as expected.
When I using the btton 1 click device goes on, double click device turns off. But when I try to control in from Domoiticz selecting on/off de device in Zigbee2Mqtt is not updated and the smart button state stays the same.
I did not do anything special wit the button, it just came in after auto discovery. ( I can see 5 stages, but there are no selector actions).
Is there something in addtion i need to do to get this working?
Runing Domoticz version 2022.1 with latest version of the plugin for Zigbee.
Thanx Hemant
Zigbee smart Button TS004F Zigbee Manufacturer _TZ3000_rco1yzb1 not working
hemant5400z
- HansOtten
- Domoticz version: 2021-1
Re: Zigbee smart Button TS004F Zigbee Manufacturer _TZ3000_rco1yzb1 not working
Sounds familiar to my experience with the Lidl Smart Switch. Same Zigbee2MTT setup.
Behaviour is the same, not of any use in Domoticz as is.
See viewtopic.php?p=294880#p294880
It seems you need to write scripts for it. See https://www.domoticz.com/wiki/Dummy_for ... tor_Switch
Raspberry Pi 4, SSD, RFlink, P1 Smart Meter. Many Zigbee devices CR2562 USB stick. Bresser via Weather Underground
Switched to Home Assistant!
hemant5400z
Hhmm,
so no functionalit, and need to write scripts for each action. I was hoping that this simple device would just turn On/Off something and was planning to use it as a toggle switch.
no wonder they were 50% off
hemant
hemant
- HansOtten
It is Domoticz which lets us down with this switch.
It seems to wrok fine in Home Assistent and with the Lidl gateway software.
Hans
Hans
hemant5400z
Unfortunately in not use HA.
I have domoticz en homebridge. To expose to homekit.
All logic is in domoticz and was not planning to use HA.
Hope someone had a nice trick.
Hemant
Hemant
