sbfspot empty data path
Gianni
Post by Gianni »
Hello
everything run in docker envoirement.
No i just setup sbf spot in a new docker and setup the domoticz plugin.
But i got this error
2022-11-19 18:40:21.768 Error: sma: Data path empty!
MY path go the the correct config file and my DB is not Empty so sbf works
Any idee's
Domoticz version: 2025.1
Re: sbfspot empty data path
As you are in a Docker you have to specify the location of the cfg file as you are in docker and not from the point of view outside the docker.
Gianni
Post by Gianni »
Hey WalterVL
Now i'm lost how can i point to the file inside the container from outside?
grts Gianni
I am not a Docker fan, just for this reason. Making everything a bit more complex. And as there are more docker versions of Domoticz each behaves different...
So the cfg file needs to be accessible from Domoticz in the docker. There are more docker users that can explain where it should be.
skippy711
Domoticz version: 2024.2
Post by skippy711 »
Following up on this post:
After a lot of testing I migrated the 'traditional' Domoticz to a Docker set up, managed to get everything up and running (Zwave2MQTT in Docker, Speedtest in Docker, plugins for Buienradar, Presence detection, Pi-hole and Kodi, scripts for backup and SNMP monitoring, P1 and OTGW) like a charm but I haven't figured out the way to point to the SBFspot.cfg. Who can help?
I appreciate waltervl's comment (I was not a Docker fan myself but gradually I managed).
Perhaps I can get SBFspot in Docker running MQTT and then do MQTT --> Domoticz, but for now I like SBFspot -> Domoticz Docker
Any help is appreciated!
