Travel time plugin
zabinskiwojciech
- Domoticz version: 4.10776
Travel time plugin
Hello everyone, I had a script that determined the time of travel from home to work and the second one from work to home stopped working from August 6th. You don't know what could have happened. I am running on the last stable release of Domoticz and Ubuntu 20.04LTS. Ubuntu constantly updated. The script was based on Google Map and API.
- gizmocuz
Re: Travel time plugin
Well it could be that you need to reauthenticate yourself via the Google API, but if someone could help you, I'm sure they would like to see your script here
zabinskiwojciech
#!/bin/bash
KEY=xxxxxxxxxxAPIxxxxxxxx
FROM=Marki+Skorupki+22
TO=Warszawa+Dobosza+1
CZAS=`curl -s "https://maps.googleapis.com/maps/api/directions/json?origin=$FROM&destination=$TO&transit_mode=driving&departure_time=now&key=$KEY" | jq '.routes[0].legs[0].duration_in_traffic.value'`
WYNIK=$(($CZAS/60))
DOMO=192.168.1.223:8084
IDX=158
wget -O - "$DOMO/json.htm?type=command¶m=udevice&idx=$IDX&nvalue=0&svalue=$WYNIK" > /dev/null 2>&1- waltervl
- Domoticz version: 2025.1
Perhaps related to google not accepting normal user/password anymore? You need to make a specific app login on your google account.
See viewtopic.php?p=290975#p290975
Additional: is the link in a browser with filled in parameters for FROM, TO and KEY giving the expected result?
"https://maps.googleapis.com/maps/api/directions/json?origin=$FROM&destination=$TO&transit_mode=driving&departure_time=now&key=$KEY"Domoticz running on Udoo X86 (on Ubuntu)
- FireWizard
Hi, @zabinskiwojciech
Is this something, that might be of interest?
viewtopic.php?p=280642&hilit=OSRM#p280642
zabinskiwojciech
Your idea is very cool but very advanced, I wanted it to tell me the time of commuting to work at a specific time and returning. I have created two buttons that are triggered at given times and the result is shown on other tiles.FireWizard wrote: Tuesday 18 October 2022 22:08 Hi, @zabinskiwojciech
zabinskiwojciech
after filling in the data, he gets a replywaltervl wrote: Tuesday 18 October 2022 13:10 Perhaps related to google not accepting normal user/password anymore? You need to make a specific app login on your google account.
Additional: is the link in a browser with filled in parameters for FROM, TO and KEY giving the expected result?Code: Select all
geocoded_waypoints
0
geocoder_status "ZERO_RESULTS"
1
geocoder_status "OK"
place_id "ChIJJQ6uPq_MHkcRgxEC0lAD2ck"
types
0 "premise"
routes []
status "NOT_FOUND"
Based on the result of the link it seems that the Google api changed or that one of the adresses cannot be found. There should be a JSON with a duration_in_traffic.value.
What happens if you use an example url from the documentation, only change the API key.
If you get an error you probably will need to update the API Key as Gizmocuz already mentioned.
If you get a good result something in your FROM or TO attributes is wrong.
Check the Google api documentation: https://developers.google.com/maps/docu ... ematrix-sh
https://maps.googleapis.com/maps/api/distancematrix/json?origins=Boston%2CMA%7CCharlestown%2CMA&destinations=Lexington%2CMA%7CConcord%2CMA&departure_time=now&key=YOUR_API_KEYIf you get a good result something in your FROM or TO attributes is wrong.
zabinskiwojciech
It seems to me that the API key is ok because on the Google website it shows the query in the statistics and the result after loading the link is as if the data were bad ... I don't know I have to do more.
- api.jpg (24 KiB) Viewed 1107 times
You have to play a little bit with the URL to see if it still works. It seems that the first address probably in Warszawa cannot be resolved (ZERO_RESULTS), the second address (in Marki) is OK.
What if you make the FROM and TO really simple like only Warszawa and Marki ?
K0enH
maybe useless to mention but you can also create a developer account with Here365 and use their API's.
I moved to that last year or something ago If I recall correctly they also have a higher limit of number of requests you can make for free...
zabinskiwojciech
Notifications from the forum do not work for me, I do not receive an email that someone replied. Today I will come back from work and play with simplifying the address.
zabinskiwojciech
https://maps.googleapis.com/maps/api/di ... xxxxxxxxxx
When entering your journey data:
Something's wrong with me, my address would disappear from my house
I don't get any notifications from this forum, I don't know what's going on.
geocoded_waypoints
0
1
place_id "ChIJQ-_mNa_MHkcRFtTargPWVsA"
types
0 "route"
routes []
status "NOT_FOUND"Something's wrong with me, my address would disappear from my house
zabinskiwojciech
you won't believe Google changed my address in its maps and that's why I couldn't refresh the page after changing to the new address provided by Google script works great thank you for helping everyone
Glad it works now!
