Problems with RazBerry 7 Pro and Domoticz
FrankCGN
Post by FrankCGN »
Hi.
I wanted to update my Domoticz installation (so far a RaZberry 2 board and Domoticz v4.10717).
For this I want to use a new RaZberry 7 Pro board and a Raspi 3B+. The Domoticz installation will be completely re-done and I want to re-learn all my devices on the new RaZberry 7 board.
Unfortunately I can't get the RaZberry 7 board to work without errors.
I have updated the RaZberry 7 board to firmware 7.28 using the Z-Way software.
Razberry 7 Daten.png (20.67 KiB) Viewed 1254 times
With a fresh installation under Buster and the stable version 2022.1 of Domoticz I get a driver error when Bluetooth is not deactivated.
If I disable Bluetooth (via the /boot/config.txt and additionally disable driver loading via raspi-blacklist.conf) the OpenZWave driver is loaded without error, the controller is recognized as a node, but the type of the controller is unknown.
If I try to include a Z-Wave device, I get an error.
Under Bullseye with the last Domoticz Beta I get the error "Z-Wave: Type_Notification, NodeID not found internally! HomeID: 0, NodeID: 255 (0xff)".
With the Z-Way software v3.2.3 the board runs without problems and I can add devices.
Does anyone have any tips on how I can get the RaZberry 7 Pro board to work with Domoticz?
Raspberry 3 - RaZberry2 Module - RFXtrx433E - Domoticz beta
Z-Wave: Popp Smoke Detector, Fibaro Motion Sensor, Fibaro Wall Plug, Popp Wall Plug
RFXtrx433E: Bresser Temp.+Hygro Sensor, rohrmotor24 RMF Blindmotor
Other: AVM Fritz!DECT200
ferrosk
Domoticz version: 2026.2
Re: Problems with RazBerry 7 Pro and Domoticz
Post by ferrosk »
Other option is to migrate from OpenZWave to Zwave JS UI (formerly ZwaveJS2MQTT). I use older version of board - RaZberry 2 (RaZberry Controller 2016 ZWave+) and it works much better for me since I migrated to Zwave JS UI. I do not have experience with RaZberry 7 Pro board but is supported too
You can follow instructions on Domoticz wiki (just replace ZwaveJS2MQTT to Zwave JS UI):
https://www.domoticz.com/wiki/ZwaveJS2MQTT
Domoticz 2026.2 on Odroid M1 and Armbian
MySensors (RFM69 Serial GW): bunch of DIY sensors/devices
Zwave (Z-Wave.me RaZberry board): Danfoss devices
Zigbee (Sonoff Dongle Plus): IKEA, Tesla devices
FrankCGN
Post by FrankCGN »
@ferrosk thanks for the tip. I was already thinking if ZwaveJS2MQTT or Zwave JS UI can be an alternative to OpenZWave, but I was not sure. But if you say that this works, then I will also take a closer look. Did you install Zwave JS UI as a Docker container or directly in the system?
ferrosk
Post by ferrosk »
Hi, yes I'm running Zwave JS UI in Docker.
Sent from my Pixel 4a using Tapatalk
