Negative temp value in Blockly
Treve
Domoticz version: v4.11474
Post by Treve »
The thermostat of the freezer is defective, I thought to solve this temporarily with a simple blockly. It seems that no negative values ​​are possible.
Can someone clarify and possibly offer me a solution.
Blockly negative temp.jpg (20.03 KiB) Viewed 5747 times
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
willemd
Re: Negative temp value in Blockly
Post by willemd »
Switch to DzVents, it is so much more powerful, although a small learning curve .....
Treve
Post by Treve »
Since I need a working script in the short term and have no time to learn myself into DZVentz.
I found a script from the late 'Waaren',
on = { timer = { 'every minute' } },
execute = function(domoticz)
local Sensor = domoticz.devices('Omnik temperature')
if Sensor.temperature >= 25 then
domoticz.devices('Omnik Ventilator').switchOn()
and adapted it without any knowledge.
local Sensor = domoticz.devices('Vriezer')
if Sensor.temperature <= -16 then
domoticz.devices('Switch 7 Vriezer').switchOn()
elseif Sensor.temperature >= -18 then
domoticz.devices('Switch 7 Vriezer').switchOff()
Can this script work?
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
plugge
Post by plugge »
You have to change:
in: if Sensor.temperature >= -16 then
and
in: elseif Sensor.temperature <= -18 then
Remember these are negative values.
If the script iteself works for you? Try it!
Treve
Post by Treve »
local Sensor = domoticz.devices('testtemp')
if Sensor.temperature <= 22 then
domoticz.devices('Lidl On/Off plug 4').switchOn()
elseif Sensor.temperature >= 24 then
domoticz.devices('Lidl On/Off plug 4').switchOff()
I created a test environment with positive temperatures, the switch turns On below 22' and Off above 24'.
Conclusion is, the script works.
Now investigate whether it also works with negative (freezing) values, or can anybody tells me if it will?
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
Treve
Post by Treve »
elseif Sensor.temperature <= -19 then
This did the trick.
good find for someone who has never dealt with dzvents until this morning.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
