The thermostat of the freezer is defective, I thought to solve this temporarily with a simple blockly. It seems that no negative values are possible.
Can someone clarify and possibly offer me a solution.
Negative temp value in Blockly
- Treve
- Domoticz version: v4.11474
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
willemd
- Domoticz version: 2026.3
Re: Negative temp value in Blockly
Switch to DzVents, it is so much more powerful, although a small learning curve .....
- Treve
Since I need a working script in the short term and have no time to learn myself into DZVentz.
I found a script from the late 'Waaren',
on = { timer = { 'every minute' } },
execute = function(domoticz)
local Sensor = domoticz.devices('Omnik temperature')
if Sensor.temperature >= 25 then
domoticz.devices('Omnik Ventilator').switchOn()
and adapted it without any knowledge.
local Sensor = domoticz.devices('Vriezer')
if Sensor.temperature <= -16 then
domoticz.devices('Switch 7 Vriezer').switchOn()
elseif Sensor.temperature >= -18 then
domoticz.devices('Switch 7 Vriezer').switchOff()
Can this script work?
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
plugge
You have to change:
in: if Sensor.temperature >= -16 then
and
in: elseif Sensor.temperature <= -18 then
Remember these are negative values.
If the script iteself works for you? Try it!
and
- Treve
local Sensor = domoticz.devices('testtemp')
if Sensor.temperature <= 22 then
domoticz.devices('Lidl On/Off plug 4').switchOn()
elseif Sensor.temperature >= 24 then
domoticz.devices('Lidl On/Off plug 4').switchOff()
I created a test environment with positive temperatures, the switch turns On below 22' and Off above 24'.
Conclusion is, the script works.
Now investigate whether it also works with negative (freezing) values, or can anybody tells me if it will?
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Treve
elseif Sensor.temperature <= -19 then
This did the trick.
good find for someone who has never dealt with dzvents until this morning.
This did the trick.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
