Thermostat resolution
timmpo
Is there any way to get virtual thermostat resolution from 0.5 to 0.1 ?
- Domoticz version: 2025.1
Re: Thermostat resolution
timmpo
I found it in domoticz/www/js/domoticz.js
tanx anyway!
tanx anyway!
function SetpointUp() {
var curValue = parseFloat($('#setpoint_popup #popup_setpoint').val());
curValue += 0.1;
//curValue = Math.round(curValue / 0.1) * 0.1;
var curValueStr = curValue.toFixed(1);
$('#setpoint_popup #popup_setpoint').val(curValueStr);
function SetpointDown() {
curValue -= 0.1;
Nautilus
As a feature request, it would be great if the resolution could be set in device parameters. As for some thermostats the resolution is 0.1, for some 0.5 and for some even 1.0. As a configurable value, everyone could set it to whatever the actual thermostat device follows...
ssk17051980
- Domoticz version: 2023.2
timmpo wrote: Thursday 29 September 2022 18:03 I found it in domoticz/www/js/domoticz.js
tanx anyway!
function SetpointUp() { var curValue = parseFloat($('#setpoint_popup #popup_setpoint').val()); curValue += 0.1; //curValue = Math.round(curValue / 0.1) * 0.1; var curValueStr = curValue.toFixed(1); $('#setpoint_popup #popup_setpoint').val(curValueStr); } function SetpointDown() { var curValue = parseFloat($('#setpoint_popup #popup_setpoint').val()); curValue -= 0.1; //curValue = Math.round(curValue / 0.1) * 0.1; var curValueStr = curValue.toFixed(1); $('#setpoint_popup #popup_setpoint').val(curValueStr); }
it seems to be a little different now
can you help us with the thermostat step?
In 2024.1 stable there is a new setpoint device that has various settings including resolution: https://www.domoticz.com/wiki/Dummy_for ... t_Setpoint
The old thermostat devices (pre 2024.1) are converted to the new setpoint device during the upgrade.
So no need to changes the JavaScript code ....
ssk17051980
waltervl wrote: Tuesday 09 January 2024 22:12 In 2024.1 stable there is a new setpoint device that has various settings including resolution: https://www.domoticz.com/wiki/Dummy_for ... t_Setpoint
Thx !!!!!
