Thermostat resolution
timmpo
Post by timmpo »
Is there any way to get virtual thermostat resolution from 0.5 to 0.1 ?
Domoticz version: 2025.1
Re: Thermostat resolution
Not easy, it is hardcoded in the source code
Edit: see for reference viewtopic.php?t=39017
timmpo
Post by timmpo »
I found it in domoticz/www/js/domoticz.js
tanx anyway!
function SetpointUp() {
	var curValue = parseFloat($('#setpoint_popup #popup_setpoint').val());
	curValue += 0.1;
	//curValue = Math.round(curValue / 0.1) * 0.1;
	var curValueStr = curValue.toFixed(1);
	$('#setpoint_popup #popup_setpoint').val(curValueStr);
function SetpointDown() {
	curValue -= 0.1;
Nautilus
Post by Nautilus »
As a feature request, it would be great if the resolution could be set in device parameters. As for some thermostats the resolution is 0.1, for some 0.5 and for some even 1.0. As a configurable value, everyone could set it to whatever the actual thermostat device follows... 8-)
ssk17051980
Domoticz version: 2023.2
Post by ssk17051980 »
timmpo wrote: Thursday 29 September 2022 18:03 I found it in domoticz/www/js/domoticz.js
tanx anyway!
	curValue += 0.1;
	curValue -= 0.1;
it seems to be a little different now
can you help us with the thermostat step?
In 2024.1 stable there is a new setpoint device that has various settings including resolution: https://www.domoticz.com/wiki/Dummy_for ... t_Setpoint
The old thermostat devices (pre 2024.1) are converted to the new setpoint device during the upgrade.
So no need to changes the JavaScript code ....
ssk17051980
waltervl wrote: Tuesday 09 January 2024 22:12 In 2024.1 stable there is a new setpoint device that has various settings including resolution: https://www.domoticz.com/wiki/Dummy_for ... t_Setpoint
Thx !!!!!
