dzvents script for garage door
hoeby
Domoticz version: V2022.1
Re: dzvents script for garage door
Post by hoeby »
I modified some things. Don't know if this is what you are looking for, but could be some start.
What is changed:
On the top of the code, there is a part on = { device = { }}
This is for the devices which needs to trigger the script. You also added the action devices.
When the action devices are added, they also trigger the script, which could give strange behavior.
You used quietOn and quietOff, this sets the deviceStatus to on/off without physically switching it
Changed this to switchOn/Off with addon .silent() to not trigger other scripts.
This part i don't get what you would like to do with it.
It is always triggered if the script is triggerd. Is Garage 2 sensor closed is active, then also this will activate the garage 2 relay for 2 sec. But not direct, but indirect. Because the else part of this code is true in this case and will set the device Garage 2 door to ON, because of that, the script if triggered again and then the if is true and will switch Garage 2 Relay
            -- if Dummi switch is pressed to activate the relay for 2sec that will open the door
            if (domoticz.devices('Garage 2 Door').state == 'On') then
                domoticz.devices('Garage 2 Relay').switchOn().forSec(2)
                domoticz.devices('Garage 2 Door').switchOn().forSec(2)
The complete modified code
			devices = {
			   'Garage 2 Door',           -- Dummy switch                    Garage 2 Door idx 73
			   'Garage 2 Sensor Closed',  -- Magnet sensor          Garage 2 Sensor Closed idx 76
        logging = {
		level = domoticz.LOG_INFO,
		marker = 'Garage 2',
	execute = function(domoticz)
	    -- if standart Remote control is used only to indicate the condition
            if (domoticz.devices('Garage 2 Sensor Closed').state == 'On') then
                domoticz.devices('Garage 2 Door').switchOn().silent()
                domoticz.notify('Garage 2', 'Garage 2 Open', domoticz.PRIORITY_EMERGENCY)
                domoticz.devices('Garage 2 Door').switchOff().silent()
                domoticz.notify('Garage 2', 'Garage 2 Closed', domoticz.PRIORITY_EMERGENCY)
            -- to switch On the garage light between sunset and sunrise
            if domoticz.devices('Garage 2 Sensor Closed').state == 'On' and domoticz.time.('at nighttime') then
                domoticz.devices('Garage 2 Light Light').switchOn()
                domoticz.devices('Garage 2 Light Light').switchOff()
heggink
Domoticz version: 12451
Post by heggink »
Looks like spam
P1 meter & solar panel
tonito1509
Domoticz version: 2021.1
Post by tonito1509 »
So i manage to make 3 scripts that are working together but i don't know how to combine them in one script. Is anybody able to help? Thanks.
script 1
            devices = {
            if (switch.state == 'On') then
                domoticz.notify('Garage 2 ', 'GARAGE 2 Open', domoticz.PRIORITY_EMERGENCY)
                domoticz.notify('Garage 2 ', 'GARAGE 2 Closed', domoticz.PRIORITY_EMERGENCY)
script 2
        timer = {
            'at nighttime'
    execute = function(domoticz, timer)
            domoticz.devices('Garage 2 Light').switchOn()
            domoticz.log('Garage Light On!', domoticz.LOG_INFO)
            domoticz.devices('Garage 2 Light').switchOff()
            domoticz.log('Garage Light Off!', domoticz.LOG_INFO)
script 3
return
    on =
        devices =
            'Garage 2 Door',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Relay',
    execute = function(dz, item)
        local relay = dz.devices(74)                                              -- Garage 2 Relay idx 74
        dz.log('State of ' .. item.name .. ' is ' .. item.state, dz.LOG_DEBUG)
        if item.active then
            relay.switchOn().forSec(2)
hoeby
Post by hoeby »
heggink wrote: Friday 22 April 2022 15:31 Looks like spam
Don't think it is spam.
But the thread looks strange, the openingspost from tonito1509 is gone.
My reply is the first post, now it looks like i started it, but it is not
@Tonito1509,
Why put everything in 1 script, when it works like you have now?
tonito1509
hoeby wrote: Monday 25 April 2022 7:04
@Tonito1509,
@hoeby
My post is gone because i was banned for some misunderstanding due to a spam replay on my first post. After discussion with the moderators I am back. Good question why in one script. I also have it in blockly and it works perfect. In one script it will be everything in one place and it will not look messy. As i said from the beginning i learn how to make a scripts in dzvents and LUA. I am self learning in my free time which is not so much so any help will be appreciated.
hoeby
Post by hoeby »
It is not tested, but give it a try.
I just copied your parts and needed to do little modifications, to get it in 1 script
Maybe there are better ways, but that is the fun with scripts. More ways to get to the working environment
If there is an error. Copy the error codeline from domoticz-log to here
            devices = { 'Garage 2 Sensor Closed',
                        'Garage 2 Door' },
            timer = { 'at nighttime' },
            if (item.trigger == 'Garage 2 Sensor Closed') then
            if (item.isTimer) then
            if (item.trigger == 'Garage 2 Door') then
                    domoticz.devices(74).switchOn().forSec(2)
tonito1509
The script was giving me an error on line 40 where was "end & }" so i removed them and no error anymore. Then when i press "Garage 2 Door" it doesn't trigger "Garage 2 Relay". When i simulate that ("Garage 2 Sensor Closed" == On ) it doesn't run " ('Garage 2 Door').switchOn().silent() ". I noticed that when the "timer = { 'at nighttime' }" is added this way is taking action every complete minute and also the script is checking every minute , but if is this way if (domoticz.time.isNightTime and switch.state == 'On') it is reacting immediately. If i am not wrong the same kind of timer problem was mentioned on another thread.
Screenshot (518).png (39.61 KiB) Viewed 963 times
Screenshot (522).png (157.74 KiB) Viewed 963 times
hoeby
Post by hoeby »
You where correct, it wasn't working, sorry my fault.
Made some changes
Only tested the "Garage 2 Door" reaction. that works in my environment.
That you get a trigger every minut is correct.
"timer = { 'at nighttime' }" means between sunset and sunrise. This will be checked every minut and therefor it is every minut true when it is between sunset and sunrise. If you need to let the timer work at 00:00hour. Then you need to modify 'at nighttime' to 'at midnight'
This line isn't going to work correctly (domoticz.time.isNightTime and switch.state == 'On')
You haven't defined 'switch' in the command switch.state, which devices you mean with it.
                        'Garage 2 Door' },
            if (item.name == 'Garage 2 Sensor Closed') then
            if (item.name == 'Garage 2 Door') then
Just copied your parts, like said.
Maybe it is because you want to extend the scripting.
But this part:
Could also be written like. You do a check on the state, but there is no difference in reaction, both do the same, why check it then?
tonito1509
hoeby wrote: Thursday 28 April 2022 14:46 [/code]
But this part:
Thank you for the help! The script work as it was expected. So, 'Garage 2 Door' is a dummy switch which is showing the condition with the garage Icon and triggering "Relay idx74" that is acting as a inching relay made from "sonoff basic" with "Tasmota " modified to only close the circuit when is "On" (main power is isolated from relay contact). When 'Garage 2 Door' is pressed it will remain "active" but the relay will goes "Off" after 2sec and the door will open. So next time when it is pressed and goes inactive it will trigger the relay again for only 2sec and the door will close. Somebody will ask why two sensors. The purpose is that something has to tell domoticz to show 'Garage 2 Door' dummy as a active when i am using the original remote control which is specific for Hörmann devices. The second sensor has to show if the door is in intermediate position or is fully open which can give you another benefits.
