New message in debug log for python plugin.
Thorgal789
Post by Thorgal789 »
Hello, just by curiosity, all is working fine, but if I increase the debug level in my python plugin, I have this kind of lines that flood the windows (more than 1 by seconds)
(ZIGBEE) Releasing lock for 'ZIGBEE'
(ZIGBEE) Acquiring lock for 'ZIGBEE'
Some know if it's something normal ? If yes, those logs are realy too much talkatives.
The plugin use a permanent connection by websocket.
Filip
Re: New message in debug log for python plugin.
Post by Filip »
I have the same especially with plugins using Threading. I just tried with the multi-threading example in the domoticz plugin folder, and got the same...
ferrosk
Domoticz version: 2023.2
Post by ferrosk »
This is known issue in Domoticz 2022.1. The fix has been released in beta channel and people are testing it, see viewtopic.php?t=38086
Domoticz 2023.2 on Odroid M1 and Armbian
MySensors (RFM69 Serial GW): bunch of DIY sensors/devices
Zwave (Z-Wave.me RaZberry board): Danfoss devices
Zigbee (Sonoff Dongle Plus): IKEA, Tesla devices
Thorgal789
Ok, thx, will make a try, in my mind the fix was just for compatibility with recent python version.
Domoticz version: 2025.1
I also do not think that the change to a Python ABI will modify the log behavior. This should be addressed to @dnpwwo but I think he has higher priorities.
Thorgal789
ferrosk
Post by ferrosk »
waltervl wrote: Sunday 27 February 2022 11:37 I also do not think that the change to a Python ABI will modify the log behavior. This should be addressed to @dnpwwo but I think he has higher priorities.
The changes (i.e. improved inter-thread locking strategy and others) in Python Framework by moving to new Python ABI fixed the cause of those log messages not just logging behavior. You can see in this thread it indeed helped to fix this problem not only for me and my plugin but also for other people using other plugins...
