Check last update on device
JeroenG
Domoticz version: 20231
Post by JeroenG »
every few (something between 3 and 14) domoticz stops getting information from my Nibe Uplink connection. Solution is to disable and enable the device in the hardware section.
What is an easy way to detect if the last update of a specific device is more then x minutes ago? If this is the case some action should be taken (flip a switch, send alert or maybe even disable/enable the connection automaticly).
Posted this in dzVents as it looks as the best way to go, but any other solution is also welcome ;).
Any suggestions?
Domoticz version: 2025.1
Re: Check last update on device
The easiest way is to set a notification on last update time, so no need to script. https://www.domoticz.com/wiki/Managing_ ... ifications
Edit: if you need more and so need to script check the following topic for inspiration: viewtopic.php?t=28446
JeroenG
Post by JeroenG »
Thanks Walter,
notification on last update will probably be good enough. Never realised that it was a dropdown ;)
