every few (something between 3 and 14) domoticz stops getting information from my Nibe Uplink connection. Solution is to disable and enable the device in the hardware section.
What is an easy way to detect if the last update of a specific device is more then x minutes ago? If this is the case some action should be taken (flip a switch, send alert or maybe even disable/enable the connection automaticly).
Posted this in dzVents as it looks as the best way to go, but any other solution is also welcome
Any suggestions?
