Goodmorning,
I would like to disable showing a new tab or popup when clicking on the news block.
Also disable opening a new tab when clicking on a frame block. (buienradar)
Is this possible?
Disable opening new tab or pop-up when clicking block
Re: Disable opening new tab or pop-up when clicking block
assume you've defined your block in CONFIG.js via:
then you can disable handling of click events by adding the following to custom.css:
or,
add the addClass block parameter:
and add the following to custom.css:
Both methods also work for frames.
blocks['news'] = {
[data-id="news"].dt_block {
pointer-events: none
blocks['news'] = {
addClass: 'noclick',
.noclick {
Thanks! that worked!
