Disable opening new tab or pop-up when clicking block
cduijker
Post by cduijker »
Goodmorning,
I would like to disable showing a new tab or popup when clicking on the news block.
Also disable opening a new tab when clicking on a frame block. (buienradar)
Is this possible?
Lokonli
Re: Disable opening new tab or pop-up when clicking block
Post by Lokonli »
assume you've defined your block in CONFIG.js via:
blocks['news'] = {
then you can disable handling of click events by adding the following to custom.css:
[data-id="news"].dt_block {
    pointer-events: none
or,
add the addClass block parameter:
blocks['news'] = {
   addClass: 'noclick',
and add the following to custom.css:
.noclick {
Both methods also work for frames.
cduijker
Post by cduijker »
Thanks! that worked!
