Zigate USB v.1 behaving differently after upgrade to 3.21
JanZorz
Post by JanZorz »
Hey,
I suspect that this would be of interest to @pipiche ;)
After upgrading Zigate USB v.1 to 3.21 - two of zigbee devices started to act strange. Konke switch (model 3AFE170100510001) and Tuya 4-way switch (TS0044).
When I press them once or twice or long press - everything works. However, they just randomly started sending commands to Zigate as if I would press them once, at random times - despite the fact that I removed Konke switch old binding and registered it fresh into Zigate.
2022-01-12 00:28:15.734 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-12 04:30:52.457 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-12 08:33:08.315 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-12 16:37:20.883 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-12 20:39:11.000 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-13 04:44:11.559 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-13 12:49:41.944 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-13 16:52:08.714 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-12 12:47:18.015 Zigate: UpdateDevice - ( Konke Switch) 0:00
2022-01-12 19:56:12.491 Zigate: UpdateDevice - ( Konke Switch) 0:00
2022-01-13 01:38:59.050 Zigate: UpdateDevice - ( Konke Switch) 0:00
2022-01-13 17:31:04.398 Zigate: UpdateDevice - ( Konke Switch) 0:00
On Tuya 4-way switch I can see that all led lights on the switch buttons goes on and then this log entry appears.
I figured out this because Konke switch was used to switch manually between "daylight" and "night" state and imagine the mayhem when all sort of things started happening in the house at 01:38am :) :) :)
Any idea what could be going on and/or how we could debug this? My wife is still mad at me because of events in the middle of the night and I would like to spare this to everyone else ;)
Cheers and thnx, Jan
JanZorz
Re: Zigate USB v.1 behaving differently after upgrade to 3.21
Post by JanZorz »
And again this night, without touching those two devices whatsoever:
2022-01-14 00:56:48.145 Zigate: UpdateDevice - ( 4w-sw-dl) 0:00
2022-01-14 00:42:39.710 Zigate: UpdateDevice - ( Konke Switch) 0:00
WTH?
Cheers, Jan
pipiche
Post by pipiche »
would it be possible to enable some debug and then drop me the log file ?
debug to be enabled are :
debugClusters
debugzigateCmd
This would produce some extensive logs (depending on how many devices you have)
JanZorz
Post by JanZorz »
30 devices...
Enabled both debugging options, lets see what I get into the log file.
pipiche
Post by pipiche »
Just had a quick look, and from my understand the Konke cannot switch Off by itself.
But can you check the settings and especially "Number of sec after the Selector is reset to Off" ?
In case you have a value above 0 , this is reprents the number of seconds before putting the selector in an Off position
Screenshot 2022-01-14 at 12.01.52.png (19.69 KiB) Viewed 1244 times
JanZorz
Post by JanZorz »
Tuya TS0044 just did that:
2022-01-14 13:03:40.173  Zigate: send_zigatecmd_raw       - [12522] 0530 022d410101000a010402000b180101070000232c317429 None Queue Length: 1
2022-01-14 13:03:40.174  Zigate: _sendData to ZiGate NOW  - [12522] 0530 022d410101000a010402000b180101070000232c317429
2022-01-14 13:03:40.226  Zigate: Transport - [12309] - Async 8012 Sqn: 66 Addr: 2d41 nPdu: 00 aPdu: 01
2022-01-14 13:03:40.278  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 67/103 sqn_aps: 67/103 Status: [00] npd
u: 00 apdu: 02
2022-01-14 13:03:40.988  Zigate: send_zigatecmd_raw       - [12523] 0100 022d410101000600000000010000 2d41 Queue Length: 1
2022-01-14 13:03:40.988  Zigate: sendData - Warning 0100/022d410101000600000000010000 already in queue this command is dropped
2022-01-14 13:03:40.988  Zigate: send_zigatecmd_raw       - [None] 0100 022d410101000600000000010000 2d41 Queue Length: 1
2022-01-14 13:03:40.989  Zigate: sendData - Warning 0100/022d410101000600000000010000 already in queue this command is dropped
2022-01-14 13:03:40.989  Zigate: send_zigatecmd_raw       - [None] 0100 022d410101000600000000010000 2d41 Queue Length: 1
2022-01-14 13:03:41.893  Zigate: Decod8011 Received [12309] for Nwkid: 2d41 with status: 00 e_sqn: 0x66/102
2022-01-14 13:03:42.198  Zigate: _sendData to ZiGate NOW  - [12523] 0100 022d410101000600000000010000
2022-01-14 13:03:42.198  Zigate: Decod8011 Received [12522] for Nwkid: 2d41 with status: 00 e_sqn: 0x67/103
2022-01-14 13:03:42.310  Zigate: Decod8000 Received         [12523] PacketType:  0100 TypeSqn: 01 sqn_app: 63/99 sqn_aps: 68/104 Status: [00] npdu: 01 apdu: 01
2022-01-14 13:03:42.466  Zigate: ReadCluster - 0006 - 2d41/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00
2022-01-14 13:03:42.470  Zigate: UpdateDevice - (       4w-sw-dl) 0:00
2022-01-14 13:03:42.471  Zigate: ReadCluster - ClusterId=0006 - reception General: On/Off: 00
2022-01-14 13:03:42.512  Zigate: Decod8011 Received [12523] for Nwkid: 2d41 with status: 00 e_sqn: 0x68/104
2022-01-14 13:03:44.126  Zigate: Transport - [12311] - Async 8012 Sqn: 69 Addr: 2d41 nPdu: 00 aPdu: 01
2022-01-14 13:03:44.129  Zigate: send_zigatecmd_raw       - [12524] 0530 022d410101000a010402000b1800010700002330317429 None Queue Length: 1
2022-01-14 13:03:44.130  Zigate: _sendData to ZiGate NOW  - [12524] 0530 022d410101000a010402000b1800010700002330317429
2022-01-14 13:03:44.234  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 6a/106 sqn_aps: 6a/106 Status: [00] npdu: 00 apdu: 02
2022-01-14 13:03:44.286  Zigate: Decod8011 Received [12311] for Nwkid: 2d41 with status: 00 e_sqn: 0x69/105
2022-01-14 13:03:44.354  Zigate: Decod8011 Received [12524] for Nwkid: 2d41 with status: 00 e_sqn: 0x6a/106
2022-01-14 13:03:48.489  Zigate: send_zigatecmd_raw       - [12525] 0530 025b120101000a010402000b18a401000000e234317429 None Queue Length: 1
2022-01-14 13:03:48.490  Zigate: _sendData to ZiGate NOW  - [12525] 0530 025b120101000a010402000b18a401000000e234317429
2022-01-14 13:03:48.598  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 6b/107 sqn_aps: 6b/107 Status: [00] npdu: 00 apdu: 01
Is that enough of data? I can send more if needed, just tell me the time-span before and after the event.
Cheers, Jan
JanZorz
Post by JanZorz »
pipiche wrote: Friday 14 January 2022 12:03 Just had a quick look, and from my understand the Konke cannot switch Off by itself.
"Number of sec after the Selector is reset to Off" was (and still is) set to 0
Cheers, Jan
JanZorz
Post by JanZorz »
Interesting thing is that when this happens to Tuya TS0044 switch - all led lights behind all four buttons goes on for a second or two and then switches off... like if it was reset remotely or something similar...
Cheers, Jan
JanZorz
Post by JanZorz »
0:00 is basically the value of "1 Click".
Cheers, Jan
pipiche
Post by pipiche »
JanZorz wrote: Friday 14 January 2022 13:11 Tuya TS0044 just did that:
u: 00 apdu: 02
Cheers, Jan
Indeed can you give me more log let say from 13:00 to 13:04
could you also provide me the export.json from > tools > tools > Plugin Devices List (RAW)
pipiche
Post by pipiche »
Can you check the battery of those 2 devices.
I did test with the Konke, and I for instance remove the battery, and then put the battery's back. This generate such behaviour . So might a low battery could trigger that.
JanZorz
Post by JanZorz »
pipiche wrote: Friday 14 January 2022 14:10
2022-01-14 13:00:08.198  Zigate: ReadCluster - 0400 - c711/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0057
2022-01-14 13:00:08.198  Zigate: readCluster - 0400 - c711/01  Attr: 0000 Type: 21 Size: 0002 0057
2022-01-14 13:00:08.198  Zigate: ReadCluster - 0400 - c711/01 - LUX Sensor: 87/87
2022-01-14 13:00:08.204  Zigate: UpdateDevice - (Zigate - lumi.sensor_motion.aq2_Lux-00158d00034d0b72-01) 87:87
2022-01-14 13:00:08.205  Zigate: ReadCluster - 0406 - c711/01 AttrId: 0000 AttrType: 18 Attsize: 0001 Status: 00 AttrValue: 01
2022-01-14 13:00:08.205  Zigate: ReadCluster - ClusterId=0406 - reception Occupancy Sensor: 01
2022-01-14 13:00:08.207  Zigate: UpdateDevice - (Senzor stopnisce - premikanje) 1:On
2022-01-14 13:00:15.151  Zigate: send_zigatecmd_raw       - [12504] 0530 02bcb70101000a010402000b183c01000000e25f307429 None Queue Length: 1
2022-01-14 13:00:15.153  Zigate: _sendData to ZiGate NOW  - [12504] 0530 02bcb70101000a010402000b183c01000000e25f307429
2022-01-14 13:00:15.259  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 50/80 sqn_aps: 50/80 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:00:15.259  Zigate: Decod8011 Received [12504] for Nwkid: bcb7 with status: 00 e_sqn: 0x50/80
2022-01-14 13:00:18.092  Zigate: ReadCluster - 0000 - e661/01 AttrId: ff01 AttrType: 42 Attsize: 001f Status: 00 AttrValue: 0121db0b0421a81305216c0006240200000000642994086521b7120a21b7bc
2022-01-14 13:00:18.092  Zigate: ReadCluster - 0000 ff01 Saddr: e661 ClusterData: 0121db0b0421a81305216c0006240200000000642994086521b7120a21b7bc
2022-01-14 13:00:18.093  Zigate: UpdateDevice - (Temp senzor Jakob - Temp+hum) 0:22.0;48.2;1
2022-01-14 13:00:18.094  Zigate: UpdateDevice - (Zigate - lumi.sens_Temp-00158d00063dd5bd-01) 22.0:22.0
2022-01-14 13:00:18.097  Zigate: UpdateDevice - (Temp senzor Jakob - Temp+hum) 0:22.0;47.9;1
2022-01-14 13:00:18.098  Zigate: UpdateDevice - (Zigate - lumi.sens_Humi-00158d00063dd5bd-01) 47.9:1
2022-01-14 13:00:27.410  Zigate: send_zigatecmd_raw       - [12505] 0530 02b0880101000a010402000b185301000000e26b307429 None Queue Length: 1
2022-01-14 13:00:27.411  Zigate: _sendData to ZiGate NOW  - [12505] 0530 02b0880101000a010402000b185301000000e26b307429
2022-01-14 13:00:27.518  Zigate: Transport - [12292] - Async 8012 Sqn: 51 Addr: 162b nPdu: 00 aPdu: 01
2022-01-14 13:00:27.519  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 52/82 sqn_aps: 52/82 Status: [00] npdu: 00 apdu: 02
2022-01-14 13:00:27.519  Zigate: Decod8011 Received [12292] for Nwkid: 162b with status: 00 e_sqn: 0x51/81
2022-01-14 13:00:27.521  Zigate: Decod8011 Received [12505] for Nwkid: b088 with status: 00 e_sqn: 0x52/82
2022-01-14 13:00:35.787  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85fa
2022-01-14 13:00:35.787  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85fa
2022-01-14 13:00:35.787  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34298/2689
2022-01-14 13:00:35.789  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2689:2689
2022-01-14 13:00:40.776  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85f8
2022-01-14 13:00:40.776  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85f8
2022-01-14 13:00:40.776  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34296/2688
2022-01-14 13:00:40.780  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2688:2688
2022-01-14 13:00:52.071  Zigate: send_zigatecmd_raw       - [12506] 0530 025b120101000a010402000b18a101000000e284307429 None Queue Length: 1
2022-01-14 13:00:52.072  Zigate: _sendData to ZiGate NOW  - [12506] 0530 025b120101000a010402000b18a101000000e284307429
2022-01-14 13:00:52.179  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 53/83 sqn_aps: 53/83 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:00:52.180  Zigate: Decod8011 Received [12506] for Nwkid: 5b12 with status: 00 e_sqn: 0x53/83
2022-01-14 13:00:53.644  Zigate: send_zigatecmd_raw       - [12507] 0530 02b0880101000a010402000b185401000000e285307429 None Queue Length: 1
2022-01-14 13:00:53.646  Zigate: _sendData to ZiGate NOW  - [12507] 0530 02b0880101000a010402000b185401000000e285307429
2022-01-14 13:00:53.751  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 54/84 sqn_aps: 54/84 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:00:53.751  Zigate: Decod8011 Received [12507] for Nwkid: b088 with status: 00 e_sqn: 0x54/84
2022-01-14 13:00:59.099  Zigate: ReadCluster - fcc0 - bcb7/01 AttrId: 00f7 AttrType: 41 Attsize: 003d Status: 00 AttrValue: 641000032815983900000000953959ba2b40963900000c45973900000000052107009a20100821160107270000000000000000092102070b20009b1001
2022-01-14 13:00:59.099  Zigate: ReadCluster fcc0 - bcb7/01 Attribute: 00f7 Type: 41 Size: 003d Data: 641000032815983900000000953959ba2b40963900000c45973900000000052107009a20100821160107270000000000000000092102070b20009b1001
2022-01-14 13:00:59.250  Zigate: ReadCluster - 0000 - 6bcc/01 AttrId: ff01 AttrType: 42 Attsize: 001d Status: 00 AttrValue: 0121810b0328090421a8130521b601062401000000000a21125b641000
2022-01-14 13:00:59.250  Zigate: ReadCluster - 0000 ff01 Saddr: 6bcc ClusterData: 0121810b0328090421a8130521b601062401000000000a21125b641000
2022-01-14 13:01:00.712  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85f5
2022-01-14 13:01:00.712  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85f5
2022-01-14 13:01:00.712  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34293/2686
2022-01-14 13:01:00.723  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2686:2686
2022-01-14 13:01:08.578  Zigate: send_zigatecmd_raw       - [12508] 0530 02bcb70101000a010402000b183e01000000e294307429 None Queue Length: 1
2022-01-14 13:01:08.579  Zigate: _sendData to ZiGate NOW  - [12508] 0530 02bcb70101000a010402000b183e01000000e294307429
2022-01-14 13:01:08.690  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 55/85 sqn_aps: 55/85 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:01:08.691  Zigate: Decod8011 Received [12508] for Nwkid: bcb7 with status: 00 e_sqn: 0x55/85
2022-01-14 13:01:10.657  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85f4
2022-01-14 13:01:10.658  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85f4
2022-01-14 13:01:10.658  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34292/2685
2022-01-14 13:01:10.662  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2685:2685
2022-01-14 13:01:15.650  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85f2
2022-01-14 13:01:15.650  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85f2
2022-01-14 13:01:15.651  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34290/2684
2022-01-14 13:01:15.654  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2684:2684
2022-01-14 13:01:20.488  Zigate: Transport - [12089] - Async 8012 Sqn: 56 Addr: 162b nPdu: 00 aPdu: 01
2022-01-14 13:01:20.489  Zigate: Decod8011 Received [12089] for Nwkid: 162b with status: 00 e_sqn: 0x56/86
2022-01-14 13:01:25.294  Zigate: ReadCluster - 0402 - 4fd9/01 AttrId: 0000 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 08dc
2022-01-14 13:01:25.294  Zigate: readCluster - 0402 - 4fd9/01 Temperature Measurement: 22.7
2022-01-14 13:01:25.301  Zigate: ReadCluster - 0405 - 4fd9/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 1062
2022-01-14 13:01:25.302  Zigate: ReadCluster - ClusterId=0405 - reception hum: 4194 - 41.9
2022-01-14 13:01:25.308  Zigate: ReadCluster - 0403 - 4fd9/01 AttrId: 0000 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 03d7
2022-01-14 13:01:25.308  Zigate: Cluster0403 - decoded value: from:03d7 to 983
2022-01-14 13:01:25.320  Zigate: UpdateDevice - (Zigate - lumi.weather_Temp+Hum+Baro-00158d0002f2f19c-01) 0:22.7;41.9;1;983.0;4
2022-01-14 13:01:25.331  Zigate: UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f2f19c-01) 0:983.0;4
2022-01-14 13:01:25.331  Zigate: ReadCluster - ClusterId=0403 - 0000 reception atm: 983
2022-01-14 13:01:25.334  Zigate: ReadCluster - 0403 - 4fd9/01 AttrId: 0014 AttrType: 28 Attsize: 0001 Status: 00 AttrValue: ff
2022-01-14 13:01:25.334  Zigate: Cluster0403 - decoded value: from:ff to 255
2022-01-14 13:01:25.334  Zigate: ReadCluster - 4fd9/01 ClusterId=0403 - Scale 0014: ff
2022-01-14 13:01:25.337  Zigate: ReadCluster - 0403 - 4fd9/01 AttrId: 0010 AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 266e
2022-01-14 13:01:25.338  Zigate: Cluster0403 - decoded value: from:266e to 9838
2022-01-14 13:01:25.340  Zigate: UpdateDevice - (Zigate - lumi.weather_Temp+Hum+Baro-00158d0002f2f19c-01) 0:22.7;41.9;1;983.8;4
2022-01-14 13:01:25.343  Zigate: UpdateDevice - (Zigate - lumi.weather_Baro-00158d0002f2f19c-01) 0:983.8;4
2022-01-14 13:01:25.344  Zigate: ReadCluster - 4fd9/01 ClusterId=0403 - Scaled value 0010: 266e
2022-01-14 13:01:28.065  Zigate: send_zigatecmd_raw       - [12509] 0100 07bcb7010107020000000003000002000301 bcb7 Queue Length: 1
2022-01-14 13:01:28.065  Zigate: send_zigatecmd_raw       - [12510] 0100 07bcb7010107020000000003030203030306 bcb7 Queue Length: 2
2022-01-14 13:01:28.065  Zigate: send_zigatecmd_raw       - [12511] 0100 07bcb7011507020000000003000002000301 bcb7 Queue Length: 3
2022-01-14 13:01:28.065  Zigate: send_zigatecmd_raw       - [12512] 0100 07bcb7011507020000000003030203030306 bcb7 Queue Length: 4
2022-01-14 13:01:28.067  Zigate: _sendData to ZiGate NOW  - [12509] 0100 07bcb7010107020000000003000002000301
2022-01-14 13:01:28.171  Zigate: Decod8000 Received         [12509] PacketType:  0100 TypeSqn: 01 sqn_app: 5c/92 sqn_aps: 57/87 Status: [00] np
du: 00 apdu: 00
2022-01-14 13:01:28.172  Zigate: _sendData to ZiGate NOW  - [12510] 0100 07bcb7010107020000000003030203030306
2022-01-14 13:01:28.176  Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0000 AttrType: 25 Attsize: 0006 Status: 00 AttrValue: 000000000a06
2022-01-14 13:01:28.176  Zigate: Cluster0702 - MsgAttrID: 0000 MsgAttType: 25 DataLen: 0006 Data: 000000000a06 decodedValue: 2566
2022-01-14 13:01:28.176  Zigate: compute_conso - 0000 Power 2566, div: 1000 --> 2566.0 Watts
2022-01-14 13:01:28.176  Zigate: Cluster0702 - 0x0000 CURRENT_SUMMATION_DELIVERED Value: 000000000a06 Conso: 2566.0
2022-01-14 13:01:28.180  Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0200 AttrType: 18 Attsize: 0001 Status: 00 AttrValue: 00
2022-01-14 13:01:28.180  Zigate: Cluster0702 - MsgAttrID: 0200 MsgAttType: 18 DataLen: 0001 Data: 00 decodedValue: 0
2022-01-14 13:01:28.180  Zigate: Cluster0702 - Status: Ok
2022-01-14 13:01:28.183  Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0301 AttrType: 22 Attsize: 0004 Status: 00 AttrValue: 00000001
2022-01-14 13:01:28.183  Zigate: Cluster0702 - MsgAttrID: 0301 MsgAttType: 22 DataLen: 0004 Data: 00000001 decodedValue: 1
2022-01-14 13:01:28.183  Zigate: Cluster0702 - bcb7/01 Multiplier: 1
2022-01-14 13:01:28.279  Zigate: Decod8000 Received         [12510] PacketType:  0100 TypeSqn: 01 sqn_app: 5d/93 sqn_aps: 58/88 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:01:28.279  Zigate: _sendData to ZiGate NOW  - [12511] 0100 07bcb7011507020000000003000002000301
2022-01-14 13:01:28.283  Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0302 AttrType: 22 Attsize: 0004 Status: 00 AttrValue: 000003e8
2022-01-14 13:01:28.283  Zigate: Cluster0702 - MsgAttrID: 0302 MsgAttType: 22 DataLen: 0004 Data: 000003e8 decodedValue: 1000
2022-01-14 13:01:28.283  Zigate: Cluster0702 - bcb7/01 Divisor: 1000
2022-01-14 13:01:28.286  Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0303 AttrType: 18 Attsize: 0001 Status: 00 AttrValue: 23
2022-01-14 13:01:28.286  Zigate: Cluster0702 - MsgAttrID: 0303 MsgAttType: 18 DataLen: 0001 Data: 23 decodedValue: 35
2022-01-14 13:01:28.286  Zigate: Cluster0702 - bcb7/01 Summation Formatting: 35
2022-01-14 13:01:28.290  Zigate: ReadCluster - 0702 - bcb7/01 AttrId: 0306 AttrType: 18 Attsize: 0001 Status: 00 AttrValue: 00
2022-01-14 13:01:28.290  Zigate: Cluster0702 - MsgAttrID: 0306 MsgAttType: 18 DataLen: 0001 Data: 00 decodedValue: 0
2022-01-14 13:01:28.290  Zigate: Cluster0702 - Divisor: Electric Metering
2022-01-14 13:01:28.387  Zigate: Decod8000 Received         [12511] PacketType:  0100 TypeSqn: 01 sqn_app: 5e/94 sqn_aps: 59/89 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:01:28.387  Zigate: _sendData to ZiGate NOW  - [12512] 0100 07bcb7011507020000000003030203030306
2022-01-14 13:01:28.494  Zigate: Decod8000 Received         [12512] PacketType:  0100 TypeSqn: 01 sqn_app: 5f/95 sqn_aps: 5a/90 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:01:37.419  Zigate: send_zigatecmd_raw       - [12513] 0530 025b120101000a010402000b18a201000000e2b1307429 None Queue Length: 1
2022-01-14 13:01:37.421  Zigate: _sendData to ZiGate NOW  - [12513] 0530 025b120101000a010402000b18a201000000e2b1307429
2022-01-14 13:01:37.525  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 5b/91 sqn_aps: 5b/91 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:01:37.525  Zigate: Decod8011 Received [12513] for Nwkid: 5b12 with status: 00 e_sqn: 0x5b/91
2022-01-14 13:01:38.108  Zigate: send_zigatecmd_raw       - [12514] 0100 07bcb701010b040000000001050b bcb7 Queue Length: 1
2022-01-14 13:01:38.110  Zigate: _sendData to ZiGate NOW  - [12514] 0100 07bcb701010b040000000001050b
2022-01-14 13:01:38.191  Zigate: Decod8000 Received         [12514] PacketType:  0100 TypeSqn: 01 sqn_app: 60/96 sqn_aps: 5c/92 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:01:38.194  Zigate: ReadCluster - 0b04 - bcb7/01 AttrId: 050b AttrType: 29 Attsize: 0002 Status: 00 AttrValue: 0000
2022-01-14 13:01:38.194  Zigate: ReadCluster 0b04 - bcb7/01 Attribute: 050b Type: 29 Size: 0002 Data: 0
2022-01-14 13:01:38.194  Zigate: ReadCluster 0b04 - bcb7/01 Power 0
2022-01-14 13:01:40.562  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85f0
2022-01-14 13:01:40.562  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85f0
2022-01-14 13:01:40.562  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34288/2683
2022-01-14 13:01:40.570  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2683:2683
2022-01-14 13:01:44.445  Zigate: ReadCluster - 0400 - 40ce/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 003d
2022-01-14 13:01:44.445  Zigate: readCluster - 0400 - 40ce/01  Attr: 0000 Type: 21 Size: 0002 003d
2022-01-14 13:01:44.445  Zigate: ReadCluster - 0400 - 40ce/01 - LUX Sensor: 61/61
2022-01-14 13:01:44.449  Zigate: UpdateDevice - (Senzor svetlobe - Jan pisarna) 61:61
2022-01-14 13:01:44.450  Zigate: ReadCluster - 0406 - 40ce/01 AttrId: 0000 AttrType: 18 Attsize: 0001 Status: 00 AttrValue: 01
2022-01-14 13:01:44.450  Zigate: ReadCluster - ClusterId=0406 - reception Occupancy Sensor: 01
2022-01-14 13:01:44.452  Zigate: UpdateDevice - (Senzor premikanja - Jan pisarna) 1:On
2022-01-14 13:01:47.874  Zigate: ReadCluster - 0000 - 162b/01 AttrId: ff01 AttrType: 42 Attsize: 002b Status: 00 AttrValue: 64100003281e98390000000095397ba0a03e052128009a2000082122130727000000000000000009210307
2022-01-14 13:01:47.874  Zigate: ReadCluster - 0000 ff01 Saddr: 162b ClusterData: 64100003281e98390000000095397ba0a03e052128009a2000082122130727000000000000000009210307
2022-01-14 13:01:50.494  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85ed
2022-01-14 13:01:50.494  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85ed
2022-01-14 13:01:50.494  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34285/2681
2022-01-14 13:01:50.499  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2681:2681
2022-01-14 13:01:58.963  Zigate: send_zigatecmd_raw       - [12515] 0530 02bcb70101000a010402000b183f01000000e2c6307429 None Queue Length: 1
2022-01-14 13:01:58.964  Zigate: _sendData to ZiGate NOW  - [12515] 0530 02bcb70101000a010402000b183f01000000e2c6307429
2022-01-14 13:01:59.071  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 5d/93 sqn_aps: 5d/93 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:01:59.071  Zigate: Decod8011 Received [12515] for Nwkid: bcb7 with status: 00 e_sqn: 0x5d/93
2022-01-14 13:02:02.296  Zigate: send_zigatecmd_raw       - [12516] 0530 02b0880101000a010402000b185501000000e2ca307429 None Queue Length: 1
2022-01-14 13:02:02.297  Zigate: _sendData to ZiGate NOW  - [12516] 0530 02b0880101000a010402000b185501000000e2ca307429
2022-01-14 13:02:02.404  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 5e/94 sqn_aps: 5e/94 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:02:02.404  Zigate: Decod8011 Received [12516] for Nwkid: b088 with status: 00 e_sqn: 0x5e/94
2022-01-14 13:02:10.423  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85ea
2022-01-14 13:02:10.423  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85ea
2022-01-14 13:02:10.423  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34282/2679
2022-01-14 13:02:10.428  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2679:2679
2022-01-14 13:02:16.469  Zigate: Transport - [12303] - Async 8012 Sqn: 5f Addr: 162b nPdu: 00 aPdu: 01
2022-01-14 13:02:16.521  Zigate: Decod8011 Received [12303] for Nwkid: 162b with status: 00 e_sqn: 0x5f/95
2022-01-14 13:02:18.104  Zigate: send_zigatecmd_raw       - [12517] 0100 07bcb70101000800000000010000 bcb7 Queue Length: 1
2022-01-14 13:02:18.104  Zigate: send_zigatecmd_raw       - [12518] 0100 07bcb70101000600000000010000 bcb7 Queue Length: 2
2022-01-14 13:02:18.106  Zigate: _sendData to ZiGate NOW  - [12517] 0100 07bcb70101000800000000010000
2022-01-14 13:02:18.198  Zigate: Decod8000 Received         [12517] PacketType:  0100 TypeSqn: 01 sqn_app: 61/97 sqn_aps: 60/96 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:02:18.206  Zigate: _sendData to ZiGate NOW  - [12518] 0100 07bcb70101000600000000010000
2022-01-14 13:02:18.306  Zigate: Decod8000 Received         [12518] PacketType:  0100 TypeSqn: 01 sqn_app: 62/98 sqn_aps: 61/97 Status: [00] npdu: 00 apdu: 00
2022-01-14 13:02:18.310  Zigate: ReadCluster - 0006 - bcb7/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00
2022-01-14 13:02:18.311  Zigate: ReadCluster - ClusterId=0006 - reception General: On/Off: 00
2022-01-14 13:02:58.443  Zigate: send_zigatecmd_raw       - [12519] 0530 02bcb70101000a010402000b184001000000e202317429 None Queue Length: 1
2022-01-14 13:02:58.445  Zigate: _sendData to ZiGate NOW  - [12519] 0530 02bcb70101000a010402000b184001000000e202317429
2022-01-14 13:02:58.555  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 62/98 sqn_aps: 62/98 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:02:58.555  Zigate: Decod8011 Received [12519] for Nwkid: bcb7 with status: 00 e_sqn: 0x62/98
2022-01-14 13:03:00.273  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85e7
2022-01-14 13:03:00.273  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85e7
2022-01-14 13:03:00.273  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34279/2677
2022-01-14 13:03:00.278  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2677:2677
2022-01-14 13:03:09.497  Zigate: Transport - [12306] - Async 8012 Sqn: 63 Addr: 162b nPdu: 00 aPdu: 01
2022-01-14 13:03:09.498  Zigate: Decod8011 Received [12306] for Nwkid: 162b with status: 00 e_sqn: 0x63/99
2022-01-14 13:03:13.941  Zigate: send_zigatecmd_raw       - [12520] 0530 02b0880101000a010402000b185601000000e211317429 None Queue Length: 1
2022-01-14 13:03:13.942  Zigate: _sendData to ZiGate NOW  - [12520] 0530 02b0880101000a010402000b185601000000e211317429
2022-01-14 13:03:14.051  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 64/100 sqn_aps: 64/100 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:03:14.051  Zigate: Decod8011 Received [12520] for Nwkid: b088 with status: 00 e_sqn: 0x64/100
2022-01-14 13:03:21.261  Zigate: send_zigatecmd_raw       - [12521] 0530 025b120101000a010402000b18a301000000e219317429 None Queue Length: 1
2022-01-14 13:03:21.262  Zigate: _sendData to ZiGate NOW  - [12521] 0530 025b120101000a010402000b18a301000000e219317429
2022-01-14 13:03:21.367  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 65/101 sqn_aps: 65/101 Status: [00] npdu: 00 apdu: 01
2022-01-14 13:03:21.367  Zigate: Decod8011 Received [12521] for Nwkid: 5b12 with status: 00 e_sqn: 0x65/101
2022-01-14 13:03:35.130  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85ea
2022-01-14 13:03:35.130  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85ea
2022-01-14 13:03:35.130  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34282/2679
2022-01-14 13:03:35.138  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2679:2679
2022-01-14 13:03:40.278  Zigate: Decod8000 Received         [  ] PacketType:  0530 TypeSqn: 01 sqn_app: 67/103 sqn_aps: 67/103 Status: [00] npdu: 00 apdu: 02
2022-01-14 13:03:48.600  Zigate: Decod8011 Received [12525] for Nwkid: 5b12 with status: 00 e_sqn: 0x6b/107
2022-01-14 13:03:55.106  Zigate: ReadCluster - 0400 - 6881/01 AttrId: 0000 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 85ed
2022-01-14 13:03:55.106  Zigate: readCluster - 0400 - 6881/01  Attr: 0000 Type: 21 Size: 0002 85ed
2022-01-14 13:03:55.106  Zigate: ReadCluster - 0400 - 6881/01 - LUX Sensor: 34285/2681
2022-01-14 13:03:55.111  Zigate: UpdateDevice - (Senzor svetlobe - okrogel) 2681:2681
export.json in pm (post length restriction :) )
Cheers, Jan
JanZorz
Post by JanZorz »
pipiche wrote: Friday 14 January 2022 14:17 Can you check the battery of those 2 devices.
In Zigate dashboard when I check for battery levels - Konke switch is on 80%, TS0044 is on 100%...
Cheers, Jan
pipiche
Post by pipiche »
can you enable debugInput and debugPairing in addition, as I suspect the device to send a Device Annoucement
JanZorz
Post by JanZorz »
pipiche wrote: Friday 14 January 2022 15:25 can you enable debugInput and debugPairing in addition, as I suspect the device to send a Device Annoucement
Done. Will post the log when it happens again.
Cheers, Jan
JanZorz
Post by JanZorz »
JanZorz wrote: Friday 14 January 2022 16:00
Cheers, Jan
Due to large size of the log - I sent it to you in PM.
Cheers, Jan
JanZorz
Post by JanZorz »
@pipiche - any luck with finding what's going on in my log files?
Through more observation - I came to few more conclusions:
- Tuya 4way switch kind of works because if you click the button it sends 1:00 value and not 0:00 as it is sent during those hiccups - so if you don't use 0:00 in any rules or triggers - you're fine. However it's annoying when hiccup occurs because all led lights go on for couple of seconds and in the night you have a switch on the wall that starts blinking for no reason.
- Konke switch: that is basically useless as if you press it once (one click) it sends 0:00 and that's the same as when hiccup occurs.
I'm wondering if those random events are connected to something that controller sends or are initiated by the device? Prior to Zigate firmware upgrade this did not happen, however.
Cheers, Jan
pipiche
Post by pipiche »
I didn’t get your logs
But as they are end device based on battery they don’t listen to incoming messages outside of the pairing process ( which I suspect is the case, but this is something which has to be initiated by the device).
Can you try to change the location and put them closed to the coordinator
JanZorz
Post by JanZorz »
pipiche wrote: Monday 24 January 2022 12:56 I didn’t get your logs
Ah, crap... I sent you logs on 17th January, but instead of putting you as recipient there was just me in to: field. Sorry. I sent you logs again, did you receive them now?
Cheers, Jan
pipiche
Post by pipiche »
no issue, please do try on the recent beta version (from now). I have push a protection to prevent handling the device annoucement.
