Page 1 of 3
Synology - script doesn't work
Posted: Wednesday 05 January 2022 9:26
by fabry91
I have a Synology NAS with Domoticz running as a docker, I previuosly have Domoticz running on a raspberry and the script for a SR-201 relay was working perfect.
Now that I migrate to Synology nas I'm having some problem to run the script, it self it is:
echo -n "11" | nc -n -w 1 192.168.0.99 6722
echo -n "21" | nc -n -w 1 192.168.0.99 6722
The first is for the on action and the second for the off action, the .sh script is present in my nas, maybe I write the wrong path?
The log file say:
Error: SQLHelper: Error script not found '/volume1/docker/Domoticz/scripts/relay_ch1_on.sh'
Thank you in advanced
Re: Synology - script doesn't work
Posted: Wednesday 05 January 2022 9:58
by EddyG
From within the folders of the Synology NAS are not reachable with the normal Synology path
It depends on how you installed the Domoticz container in Docker.
So tell us the install.
Posted: Wednesday 05 January 2022 11:02
by fabry91
EddyG wrote: Wednesday 05 January 2022 9:58
Hello Eddy,
thank you for your reply!
i have followed this docker guide:
https://registry.hub.docker.com/r/domoticz/domoticz
I don't know which one of these two path is the installation path container of Domoticz:
Posted: Wednesday 05 January 2022 11:28
by EddyG
Did you follow the docker run method or the docker-compose methode
and what is the part that you used in
-v <path for config files>:/opt/domoticz/userdata \
or
volumes:
- ./config:/opt/domoticz/userdata
And if you used the compose methode, what path on your Synology is that docker-compose.yaml file
Posted: Wednesday 05 January 2022 11:47
by fabry91
EddyG wrote: Wednesday 05 January 2022 11:28
or
volumes:
I don't remember which method I followed
where can I find the docker-compose.yaml file? Is in the docker folder of volume1?
Anyway I checked the container log of the first day when I installed Domoticz with docker, it seems to be opt/domoticz/...
But if I check the /volume1/opt/ I only find "containerd" without any domoticz folder
Posted: Wednesday 05 January 2022 12:15
by EddyG
Do you know where your domoticz.db file is placed? normally the scripts and plugin dirs are below that one.
Could be /Volume1/docker/Domoticz
Posted: Wednesday 05 January 2022 12:26
by fabry91
EddyG wrote: Wednesday 05 January 2022 12:15
Yes it is placed in the docker/Domoticz folder, and also the scripts are presents in the scripts folder:
Posted: Wednesday 05 January 2022 12:44
by EddyG
Your script location from within docker is not
but probably
/opt/domoticz/userdata/scripts/relay_ch1_on.sh
you could check that with
docker run -it domoticz/domoticz /bin/bash
ls -al /opt/domoticz/userdata/scripts/
exit docker with just exit.
Posted: Wednesday 05 January 2022 12:49
by fabry91
EddyG wrote: Wednesday 05 January 2022 12:44
but probably
It can't find the path if I search:
Posted: Wednesday 05 January 2022 12:55
by EddyG
Then you have a problem with the Domoticz docker installation.
The scripts and plugins directories are not brought outside of docker and cannot be accessed.
Now it depends on the method how you installed Domoticz in docker.
Just to give an idea. My test system (raspberry) runs with this compose file.
version: '2.1'
services:
domoticz:
image: domoticz/domoticz:latest
container_name: domoticz
restart: unless-stopped
# Pass devices to container
devices:
- "/dev/serial/by-id/usb-0658_0200-if00:/dev/ttyACM0"
ports:
- "8080:8080"
volumes:
- /var/lib/docker/volumes/domoticz:/opt/domoticz/userdata
- /var/lib/docker/volumes/domoticz/www/templates:/opt/domoticz/www/templates
- /var/lib/docker/volumes/domoticz/scripts:/opt/domoticz/scripts
environment:
- TZ=Europe/Amsterdam
- LOG_PATH=/opt/domoticz/userdata/domoticz.log
It gets the www/templates and scripts directories outside of docker.
Posted: Wednesday 05 January 2022 12:59
by fabry91
EddyG wrote: Wednesday 05 January 2022 12:55
Okay, but why the plugin that I have placed in "volume1/docker/domoticz/plugin" are working and I can see in the hardware tab?
Posted: Wednesday 05 January 2022 13:04
by EddyG
I have no idea, because I don't know you setup. "domoticz" is an other dir then "Domoticz", or did you mistype the "D"?
BUT did you check if the suggested script path worked?
Or
/opt/domoticz/scripts/relay_ch1_on.sh
Posted: Wednesday 05 January 2022 13:10
by fabry91
EddyG wrote: Wednesday 05 January 2022 13:04
I mistype the "D", the setup it seems correct because also the container volume path is "/opt/domoticz/userdate/", maybe I need to copy the scripts file in "/volume1/docker/domoticz/scripts" to "/opt/domoticz/scripts" folder?
Posted: Wednesday 05 January 2022 13:11
What is in /opt/domoticz (ls /opt/domoticz) from within the docker container? Is there a scripts folder? And what is in scripts?
Then use could use /opt/domoticz/scripts/relay_ch1_on.sh as action
Posted: Wednesday 05 January 2022 13:15
by fabry91
waltervl wrote: Wednesday 05 January 2022 13:11
Here what there is inside "/opt/domoticz/scripts/":
Posted: Wednesday 05 January 2022 15:10
by EddyG
fabry91 wrote: Wednesday 05 January 2022 13:10
So add /volume1/docker/Domoticz/scripts with /opt/domoticz/scripts to the path in the docker GUI on the Synology.
Keep in mind that you have to change the action path in Domoticz too.
Posted: Wednesday 05 January 2022 15:19
by fabry91
EddyG wrote: Wednesday 05 January 2022 15:10
Added folder "docker/domoticz/scripts" with mount path "opt/domoticz/scripts" but same result:
Posted: Wednesday 05 January 2022 15:24
by EddyG
same typo "domoticz" -> "Domoticz" in scripts action path in Domoticz
AND you should change the path.
Remember: Inside docker path start with /opt/domoticz
Outside docker path start with /volume1/docker/Domoticz
Posted: Wednesday 05 January 2022 15:40
by fabry91
EddyG wrote: Wednesday 05 January 2022 15:24
Yes, check, everything is right?
Posted: Wednesday 05 January 2022 15:45
by EddyG
It should be:
script:///opt/domoticz/scripts/relay....
because Domoticz is inside docker and using paths like /opt/domoticz/.....
You could check what the right path is by going inside docker.
