Synology - script doesn't work
fabry91
Domoticz version: 2022.2
Post by fabry91 »
I have a Synology NAS with Domoticz running as a docker, I previuosly have Domoticz running on a raspberry and the script for a SR-201 relay was working perfect.
Now that I migrate to Synology nas I'm having some problem to run the script, it self it is:
echo -n "11" | nc -n -w 1 192.168.0.99 6722
echo -n "21" | nc -n -w 1 192.168.0.99 6722
The first is for the on action and the second for the off action, the .sh script is present in my nas, maybe I write the wrong path? :roll:
The log file say:
Error: SQLHelper: Error script not found '/volume1/docker/Domoticz/scripts/relay_ch1_on.sh'
Thank you in advanced
EddyG
Re: Synology - script doesn't work
Post by EddyG »
From within the folders of the Synology NAS are not reachable with the normal Synology path
It depends on how you installed the Domoticz container in Docker.
So tell us the install.
fabry91
Post by fabry91 »
EddyG wrote: Wednesday 05 January 2022 9:58 From within the folders of the Synology NAS are not reachable with the normal Synology path
Hello Eddy,
thank you for your reply!
i have followed this docker guide: https://registry.hub.docker.com/r/domoticz/domoticz
I don't know which one of these two path is the installation path container of Domoticz:
EddyG
Post by EddyG »
fabry91 wrote: Wednesday 05 January 2022 11:02 i have followed this docker guide: https://registry.hub.docker.com/r/domoticz/domoticz
Did you follow the docker run method or the docker-compose methode
and what is the part that you used in
-v <path for config files>:/opt/domoticz/userdata \
or
    volumes:
      - ./config:/opt/domoticz/userdata
And if you used the compose methode, what path on your Synology is that docker-compose.yaml file
fabry91
Post by fabry91 »
EddyG wrote: Wednesday 05 January 2022 11:28
or
    volumes:
I don't remember which method I followed :( where can I find the docker-compose.yaml file? Is in the docker folder of volume1?
Anyway I checked the container log of the first day when I installed Domoticz with docker, it seems to be opt/domoticz/...
But if I check the /volume1/opt/ I only find "containerd" without any domoticz folder
EddyG
Post by EddyG »
Do you know where your domoticz.db file is placed? normally the scripts and plugin dirs are below that one.
Could be /Volume1/docker/Domoticz
fabry91
Post by fabry91 »
EddyG wrote: Wednesday 05 January 2022 12:15 Do you know where your domoticz.db file is placed? normally the scripts and plugin dirs are below that one.
Yes it is placed in the docker/Domoticz folder, and also the scripts are presents in the scripts folder:
Last edited by fabry91 on Wednesday 05 January 2022 12:47, edited 1 time in total.
EddyG
Post by EddyG »
Your script location from within docker is not
but probably
/opt/domoticz/userdata/scripts/relay_ch1_on.sh
you could check that with
docker run -it domoticz/domoticz /bin/bash
ls -al /opt/domoticz/userdata/scripts/
exit docker with just exit.
fabry91
Post by fabry91 »
EddyG wrote: Wednesday 05 January 2022 12:44 Your script location from within docker is not
but probably
It can't find the path if I search:
EddyG
Post by EddyG »
Then you have a problem with the Domoticz docker installation.
The scripts and plugins directories are not brought outside of docker and cannot be accessed.
Now it depends on the method how you installed Domoticz in docker.
Just to give an idea. My test system (raspberry) runs with this compose file.
version: '2.1'
services:
  domoticz:
    image: domoticz/domoticz:latest
    container_name: domoticz
    restart: unless-stopped
    # Pass devices to container
    devices:
       - "/dev/serial/by-id/usb-0658_0200-if00:/dev/ttyACM0"
    ports:
      - "8080:8080"
    volumes:
      - /var/lib/docker/volumes/domoticz:/opt/domoticz/userdata
      - /var/lib/docker/volumes/domoticz/www/templates:/opt/domoticz/www/templates
      - /var/lib/docker/volumes/domoticz/scripts:/opt/domoticz/scripts
    environment:
      - TZ=Europe/Amsterdam
      - LOG_PATH=/opt/domoticz/userdata/domoticz.log
It gets the www/templates and scripts directories outside of docker.
fabry91
Post by fabry91 »
EddyG wrote: Wednesday 05 January 2022 12:55 Then you have a problem with the Domoticz docker installation.
Okay, but why the plugin that I have placed in "volume1/docker/domoticz/plugin" are working and I can see in the hardware tab? :|
EddyG
Post by EddyG »
I have no idea, because I don't know you setup. "domoticz" is an other dir then "Domoticz", or did you mistype the "D"?
BUT did you check if the suggested script path worked?
Or
/opt/domoticz/scripts/relay_ch1_on.sh
fabry91
Post by fabry91 »
EddyG wrote: Wednesday 05 January 2022 13:04 I have no idea, because I don't know you setup. "domoticz" is an other dir then "Domoticz", or did you mistype the "D"?
I mistype the "D", the setup it seems correct because also the container volume path is "/opt/domoticz/userdate/", maybe I need to copy the scripts file in "/volume1/docker/domoticz/scripts" to "/opt/domoticz/scripts" folder?
Domoticz version: 2025.1
What is in /opt/domoticz (ls /opt/domoticz) from within the docker container? Is there a scripts folder? And what is in scripts?
Then use could use /opt/domoticz/scripts/relay_ch1_on.sh as action
fabry91
Post by fabry91 »
waltervl wrote: Wednesday 05 January 2022 13:11 What is in /opt/domoticz (ls /opt/domoticz) from within the docker container? Is there a scripts folder? And what is in scripts?
Here what there is inside "/opt/domoticz/scripts/":
EddyG
Post by EddyG »
fabry91 wrote: Wednesday 05 January 2022 13:10
So add /volume1/docker/Domoticz/scripts with /opt/domoticz/scripts to the path in the docker GUI on the Synology.
Keep in mind that you have to change the action path in Domoticz too.
fabry91
Post by fabry91 »
EddyG wrote: Wednesday 05 January 2022 15:10
Added folder "docker/domoticz/scripts" with mount path "opt/domoticz/scripts" but same result:
EddyG
Post by EddyG »
same typo "domoticz" -> "Domoticz" in scripts action path in Domoticz
AND you should change the path.
Remember: Inside docker path start with /opt/domoticz
Outside docker path start with /volume1/docker/Domoticz
fabry91
Post by fabry91 »
EddyG wrote: Wednesday 05 January 2022 15:24 same typo "domoticz" -> "Domoticz" in scripts action path in Domoticz
Yes, check, everything is right?
EddyG
Post by EddyG »
It should be:
script:///opt/domoticz/scripts/relay....
because Domoticz is inside docker and using paths like /opt/domoticz/.....
You could check what the right path is by going inside docker.
