Dashticz - v3.8.9 beta
Lokonli
Post by Lokonli »
A new Dashticz release with the following functionality:
* Scaling of frame content
Use the new block parameters 'scale2fit' and 'aspectratio' to define the scaling and height adjustment.
* Dials now also support blinds
See release notes and documentation via:
https://dashticz.readthedocs.io/en/beta ... 23-12-2021
madpatrick
Domoticz version: 2025.2
Re: Dashticz - v3.8.9 beta
Post by madpatrick »
Hi Lokonli,
Is it possible to make the text size a bit bigger ?
When i try
.dialbtn.up {
    font-size: 150%
The dial is meshed up a bit
Also is it possible to make the dial a bit larger
Width 3 is a bit to big and width 2 a bit to small :? :?
I'm trying to get 5 dial in 1 row
And is it possible to add Title to the Selector dial?
Something like this ?
epost
Post by epost »
I have updated from version 3.8.7 to version 3.8.9
As a result, the decimals have changed and the comma has become a period.
How can I change this back to the old format?
Krenstik
Post by Krenstik »
use a : decimals: 1, id dial text.....
Lokonli
Post by Lokonli »
madpatrick wrote: Friday 24 December 2021 10:04 Hi Lokonli,
When i try
.dialbtn.up {
    font-size: 150%
I've made a little update.
Now you can change the up/down text size via:
.up .text, .down .text {
  font-size: 200%
madpatrick
Thanks.
It is working on my PC screen, but on my tablet is remains unchanged
  font-size: 40px !important
Is it possible to adjust the text in the middle also
epost
Post by epost »
Hi Lokonli,
Do you also have a solution for the Gas dial.
Decimals: 1 doesn't work here.
blocks['Gasmeter'] = {
idx: 464,
title: 'Gas',
type: 'dial',
values: [{value:'Counter', decimals: 0, unit:' m3'}],
setpoint: 5,
min: 0,
max: 10,
width: 6,
shownumbers: true,
showring: true,
animation: false,
showunit:true
Lokonli
Post by Lokonli »
madpatrick wrote: Tuesday 28 December 2021 12:21 Thanks.
It works on my tables (android and iOS). Can it be that the screen resolution is relatively high? Then probably the 40px may still be rather small.
Try with relative size:
   font-size: 200%
To change all the font sizes in a blinds button:
.text {
  font-size: 200%
This probably is a bit too big for a two line middle row. You could add:
.middle .text {
  font-size: 130%
Lokonli
Post by Lokonli »
epost wrote: Tuesday 28 December 2021 12:57 Hi Lokonli,
idx: 464,
title: 'Gas',
type: 'dial',
setpoint: 5,
min: 0,
max: 10,
width: 6,
shownumbers: true,
showring: true,
animation: false,
showunit:true
I've made a small fix. Update Dashticz with 'git pull'.
The following will work:
idx: 464,
title: 'Gas',
type: 'dial',
setpoint: 5,
min: 0,
max: 10,
width: 6,
shownumbers: true,
showring: true,
animation: false,
showunit:true,
decimals: 1
madpatrick
Lokonli wrote: Tuesday 28 December 2021 13:44
   font-size: 200%
.text {
  font-size: 200%
.middle .text {
  font-size: 130%
Now it is working !
The resulotion of the tablet is 1280x800. but i think the 8" is a bit small for my eyes...... :D
Do you think it is possible to add a title to the selector dials?
That would make it perfect for me.
epost
Post by epost »
Hi Lokonli,
The Gas dial now works as before.
Thank You very much
I have another item that changed after the update.
The decimal comma has been replaced by a period
blocks['zolder'] = {
idx: 510,
title: 'Zolder',
type: 'dial',
setpoint: 20,
min: 5,
max: 45,
width: 6,
shownumbers: true,
showring: true,
showunit: true,
last_update: true,
animation: false
Lokonli
Post by Lokonli »
epost wrote: Tuesday 28 December 2021 15:56 Hi Lokonli,
Thank You very much
idx: 510,
title: 'Zolder',
type: 'dial',
setpoint: 20,
min: 5,
max: 45,
width: 6,
shownumbers: true,
showring: true,
showunit: true,
last_update: true,
animation: false
Should work again with latest beta.
epost
Post by epost »
Lokonli,
The decimal comma works perfectly
Thank You very much
besix
Post by besix »
Welcome
I want to add the "usage" value from such a device to a regular switch
Json
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CounterToday" : "0 kWh",
			"CustomImage" : 0,
			"Data" : "0.020 kWh",
			"Description" : "",
			"EnergyMeterMode" : "0",
			"Favorite" : 0,
			"HardwareDisabled" : false,
			"HardwareID" : 6,
			"HardwareName" : "Shelly",
			"HardwareType" : "Shelly MQTT",
			"HardwareTypeVal" : 94,
			"HaveTimeout" : false,
			"ID" : "shelly1pm-84CCA8ACB7B8-0-energy",
			"LastUpdate" : "2021-12-28 15:18:07",
			"Name" : "Pompa Pob\u00f3r",
			"Notifications" : "false",
			"PlanID" : "2",
			"PlanIDs" :
				2
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "kWh",
			"SwitchTypeVal" : 0,
			"Timers" : "false",
			"Type" : "General",
			"TypeImg" : "current",
			"Unit" : 4,
			"Usage" : "0 Watt",
			"Used" : 1,
			"XOffset" : "363",
			"YOffset" : "503",
			"idx" : "15"
How to do it with this example ?
blocks['sw1'] = {
  idx: 1056,
  type:'dial',
  values: [
      idx: 1057,
      isNeedle: true
  width: 6,
  showring: true,
  shownumbers: true,
  min: 0,
  max: 10
The switch has an idx of 12 and Shelly from Usage has an idx of 15
How do I put idx 15 in values ​​[
gives me "DATE"
Lokonli
Post by Lokonli »
I would expect by adding the value parameter and setting idx correctly, like:
values: [
      idx: 15,
      isNeedle: true,
      value: 'Usage'
besix
Post by besix »
Perfectly
Thank you very much
madpatrick
Hi Lokonli,
Another question (sorry for the many questions)
When I push 1 dial on or off the test will dissapear.
Same when i test it on my pc wih the mouse, but then i will come back if the mouse the not on the dial
What can this be ?
This is my custom.css for these dials
.dial-center .value					{color: white !important;font-size: 130% !important;}
.dial .device 						{font-size: 14px;padding-top: 10px !important}
and i used in config.js
iconSwitch: ' '
to remove the icon due to limited space on my small tablet
2021-12-29 13_45_07-Dashticz.png (276.8 KiB) Viewed 1821 times
