Retrieve and save data from json api  [Solved]
steef27
Post by steef27 »
I would like to retrieve the price of a share every day and save it in a custom sensor.
I get the price with a json api call. I just can't manage to save the value after "02. open".
Does anyone have an idea?
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
-- API call
local config = assert(io.popen('curl "https://www.alphavantage.co/query?function=GLOBAL_QUOTE&symbol='..symbol..'&apikey='..apikey..'&datatype=json"'))
        local Stringjson = config:read('*all')
        --print(Stringjson)
        config:close()
        local jsonData = json:decode(Stringjson)
Domoticz version: 2025.1
Re: Retrieve and save data from json api
You better use the dzVents openURL function.
Check for example viewtopic.php?p=278473#p278473
steef27
Post by steef27 »
ok, good suggestion!
How do I retrieve and save data behind "05. price"?
I am not very experienced with this format.
Re: Retrieve and save data from json api  [Solved]
Should be something like below but it is not helping that the json field names have dots and spaces. So perhaps some special action is needed. I am also no expert.
if (item.isJSON) then
					local result_table = item.json['Global Quote']
					local price = result_table['05. price']
steef27
Post by steef27 »
Thanks, that works perfect! :D
