Dashticz : border-color dial bar primary
Doudy
Post by Doudy »
When i do in custom.css :
/*T° Pergola*/
.dial[data-id='temp_hum_256'] .dial .bar.primary {
  border-color: #ff0000;
I have following :
I would like to change the color according to the T ° in custom.js in an afterGetDevices function
I do this in custom.js (with test values) :
function afterGetDevices(){
	var devices = Domoticz.getAllDevices();
	var device256=devices[256];  //Pergola
	var value256 = parseFloat(device256.Data);
	if ((value256>=22) &&  (value256<24)) {
			console.log("value256 : 22-24 : " +value256);
			$('.block_temp_hum_256').addClass('bar_color_jaune');
	else if ((value256>=19) &&  (value256<22)) {
			console.log("value256 : 19-22 : " +value256);
			console.log(device);
			$('.block_temp_hum_256').addClass('bar_color_rouge ');
	else if ((value256>=15) &&  (value256<19)){
			console.log("value256 : 15-19 : " +value256);
			$('.block.temp_hum_256').addClass('bar_color_bleu ');
and this in custom.css
.bar_color_jaune {
		border-color: #ffff00 !important;
.bar_color_rouge {
		border-color: #ff0000 !important;
.bar_color_bleu {
		border-color: #0008ff !important;
But i have this:
an idea ?
HansieNL
Re: Dashticz : border-color dial bar primary
Post by HansieNL »
There’s a space after bleu. Don’t know if this fix your problem if you remove the space.
Maybe you can try.
Blah blah blah
Doudy
Post by Doudy »
HansieNL wrote: Monday 30 August 2021 17:30 $('.block.temp_hum_256').addClass('bar_color_bleu ');
Maybe you can try.
I deleted the space without success :(
Doudy
Post by Doudy »
nobody ?
:roll:
Doudy
Post by Doudy »
nobody to help me :?:
Diplo95
Domoticz version: 2021.1
Post by Diplo95 »
I'm really not a specialist, but reading your code triggers an interrogation.
It seems your device with idx = 256 gives you temp and humidity. So, are you sure your code makes a test on the right data : temperature, not on humidity ?
Domoticz v2021.1 on Raspberry Pi 3B+
Raspbian Buster
ConBee II + Xiaomi devices
Zwave
Doudy
Post by Doudy »
Diplo95 wrote: Friday 10 September 2021 10:17 Hello,
Device with idx 256 :
"ActTime": 1631264229,
"AstrTwilightEnd": "22:06",
"AstrTwilightStart": "05:17",
"CivTwilightEnd": "20:44",
"CivTwilightStart": "06:40",
"DayLength": "12:57",
"NautTwilightEnd": "21:24",
"NautTwilightStart": "06:00",
"ServerTime": "2021-09-10 10:57:09",
"SunAtSouth": "13:42",
"Sunrise": "07:13",
"Sunset": "20:10",
"app_version": "2020.2",
"result": [
"AddjMulti": 1.0,
"AddjMulti2": 1.0,
"AddjValue": 0.0,
"AddjValue2": 0.0,
"BatteryLevel": 100,
"CustomImage": 0,
"Data": "20.2 C",
"Description": "",
"Favorite": 0,
"HardwareID": 4,
"HardwareName": "RFXCOM",
"HardwareType": "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
"HardwareTypeVal": 1,
"HaveTimeout": false,
"ID": "0002",
"LastUpdate": "2021-09-10 10:56:48",
"Name": "T-Pergola-1",
"Notifications": "false",
"PlanID": "0",
"PlanIDs": [
0
"Protected": false,
"ShowNotifications": true,
"SignalLevel": 5,
"SubType": "THR128/138, THC138",
"Temp": 20.199999999999999,
"Timers": "false",
"Type": "Temp",
"TypeImg": "temperature",
"Unit": 2,
"Used": 1,
"XOffset": "0",
"YOffset": "0",
"idx": "256",
"trend": 3
"status": "OK",
"title": "Devices"
Data or Temp = correct temperature
The value at the log file (F12) :
console.log("value256 :  " +value256);
VM54:381 value256 :  20.4
Is the correct value of temperature
It seems to me that the problem must lie in this line :
Diplo95
Post by Diplo95 »
Have you tried without 'else' ?
Raspbian Buster
Zwave
Doudy
Post by Doudy »
Yes. I have tried with this
custom.js
	var addClass;
	if (value256>=10) {
			console.log("value256++++++++ : >10 : " +value256);
			$('.block_temp_hum_256').addClass('bar_color_T26');
custom.css
.bar_color_T26 {border-color: #ff0000 !important;}
same result :?
Lokonli
Post by Lokonli »
A few months ago I've added some functionality to make some customizations a bit easier with the deviceHook function.
Add the following to custom.js:
function deviceHook(device) {
    if (device.idx==256) {
      console.log('hook for device 256');
      var value256=parseFloat(device.Data);
			device.deviceStatus='bar_color_jaune';
			device.deviceStatus='bar_color_rouge';
			device.deviceStatus='bar_color_bleu';
By setting the deviceStatus field of a device, the deviceStatus value is automatically added as CSS class to the block that uses that device.
Then the next tricky part is to find the correct CSS styling. For dials that's not so easy, because the dial block is pretty complex.
If for instance you want to change the colored ring, add the following to custom.css:
.bar_color_rouge .primary, .bar_color_rouge .secondary {
    border-color: red !important
.bar_color_bleu .primary, .bar_color_bleu .secondary {
    border-color: blue !important
.bar_color_jaune .primary, .bar_color_jaune .secondary {
    border-color: yellow !important
Enjoy:)
Doudy
Post by Doudy »
Great :D
Thank you so much.
I could have searched for a long time.
Wonderful.
(For this test I have change the if values)
Lokonli
Post by Lokonli »
Nice :)
Doudy
Post by Doudy »
If that can help someone!
custom.css
By T ° (Same values used in Domoticz / Monitor )
.bar_color_T35 .primary, .bar_color_T35 .secondary {border-color: #FF0000 !important;}
.bar_color_T34 .primary, .bar_color_T34 .secondary {border-color: #FE1400 !important;}
.bar_color_T33 .primary, .bar_color_T33 .secondary {border-color: #FD2800 !important;}
.bar_color_T32 .primary, .bar_color_T32 .secondary {border-color: #FD3C00 !important;}
.bar_color_T31 .primary, .bar_color_T31 .secondary {border-color: #FC5000 !important;}
.bar_color_T30 .primary, .bar_color_T30 .secondary {border-color: #FC6500 !important;}
.bar_color_T29 .primary, .bar_color_T29 .secondary {border-color: #FC6F0A !important;}
.bar_color_T28 .primary, .bar_color_T28 .secondary {border-color: #FC7A14 !important;}
.bar_color_T27 .primary, .bar_color_T27 .secondary {border-color: #FC841E !important;}
.bar_color_T26 .primary, .bar_color_T26 .secondary {border-color: #FC8F28 !important;}
.bar_color_T25 .primary, .bar_color_T25 .secondary {border-color: #FC9A32 !important;}
.bar_color_T24 .primary, .bar_color_T24 .secondary {border-color: #FCA43C !important;}
.bar_color_T23 .primary, .bar_color_T23 .secondary {border-color: #FCAF46 !important;}
.bar_color_T22 .primary, .bar_color_T22 .secondary {border-color: #FCB950 !important;}
.bar_color_T21 .primary, .bar_color_T21 .secondary {border-color: #FCC45A !important;}
.bar_color_T20 .primary, .bar_color_T20 .secondary {border-color: #FCCF65 !important;}
.bar_color_T19 .primary, .bar_color_T19 .secondary {border-color: #FCD270 !important;}
.bar_color_T18 .primary, .bar_color_T18 .secondary {border-color: #FDD67B !important;}
.bar_color_T17 .primary, .bar_color_T17 .secondary {border-color: #FDDA87 !important;}
.bar_color_T16 .primary, .bar_color_T16 .secondary {border-color: #FEDE92 !important;}
.bar_color_T15 .primary, .bar_color_T15 .secondary {border-color: #FFE29E !important;}
.bar_color_T14 .primary, .bar_color_T14 .secondary {border-color: #F8E5A1 !important;}
.bar_color_T13 .primary, .bar_color_T13 .secondary {border-color: #F1E9A4 !important;}
.bar_color_T12 .primary, .bar_color_T12 .secondary {border-color: #EAEDA7 !important;}
.bar_color_T11 .primary, .bar_color_T11 .secondary {border-color: #E3F1AA !important;}
.bar_color_T10 .primary, .bar_color_T10 .secondary {border-color: #DDF5AE !important;}
.bar_color_T9 .primary, .bar_color_T9 .secondary {border-color: #D3F5B7 !important;}
.bar_color_T8 .primary, .bar_color_T8 .secondary {border-color: #CAF5C0 !important;}
.bar_color_T7 .primary, .bar_color_T7 .secondary {border-color: #C0F5C9 !important;}
.bar_color_T6 .primary, .bar_color_T6 .secondary {border-color: #B7F5D2 !important;}
.bar_color_T5 .primary, .bar_color_T5 .secondary {border-color: #AEF5DC !important;}
.bar_color_T4 .primary, .bar_color_T4 .secondary {border-color: #AEF1E1 !important;}
.bar_color_T3 .primary, .bar_color_T3 .secondary {border-color: #AEEDE6 !important;}
.bar_color_T2 .primary, .bar_color_T2 .secondary {border-color: #AEEAEB !important;}
.bar_color_T1 .primary, .bar_color_T1 .secondary {border-color: #AEE6F0 !important;}
.bar_color_T0 .primary, .bar_color_T0 .secondary {border-color: #AEE3F5 !important;}
.bar_color_T00 .primary, .bar_color_T00 .secondary {border-color: #EBF4F7 !important;}
custom.js
By Device
function deviceHook(device){
	//Living
	if (device.idx==39)  {console.log('hook for device 39'); var value39=parseFloat(device.Data);
	if 	   (value39>=35) {console.log("value39 : >=35 : " +value39); device.deviceStatus='bar_color_T35'}
	else if ((value39>=34) &&  (value39<35)){console.log("value39 : 34-35 : " +value39); device.deviceStatus='bar_color_T35'}
	else if ((value39>=33) &&  (value39<34)){console.log("value39 : 33-34 : " +value39); device.deviceStatus='bar_color_T34'}
	else if ((value39>=32) &&  (value39<33)){console.log("value39 : 32-33 : " +value39); device.deviceStatus='bar_color_T33'}
	else if ((value39>=31) &&  (value39<32)){console.log("value39 : 31-32 : " +value39); device.deviceStatus='bar_color_T32'}
	else if ((value39>=30) &&  (value39<31)){console.log("value39 : 30-31 : " +value39); device.deviceStatus='bar_color_T31'}
	else if ((value39>=29) &&  (value39<30)){console.log("value39 : 29-30 : " +value39); device.deviceStatus='bar_color_T30'}
	else if ((value39>=28) &&  (value39<29)){console.log("value39 : 28-29 : " +value39); device.deviceStatus='bar_color_T29'}
	else if ((value39>=27) &&  (value39<28)){console.log("value39 : 27-28 : " +value39); device.deviceStatus='bar_color_T28'}
	else if ((value39>=26) &&  (value39<27)){console.log("value39 : 26-27 : " +value39); device.deviceStatus='bar_color_T27'}
	else if ((value39>=25) &&  (value39<26)){console.log("value39 : 25-26 : " +value39); device.deviceStatus='bar_color_T26'}
	else if ((value39>=24) &&  (value39<25)){console.log("value39 : 24-25 : " +value39); device.deviceStatus='bar_color_T25'}
	else if ((value39>=23) &&  (value39<24)){console.log("value39 : 23-24 : " +value39); device.deviceStatus='bar_color_T24'}
	else if ((value39>=22) &&  (value39<23)){console.log("value39 : 22-23 : " +value39); device.deviceStatus='bar_color_T23'}
	else if ((value39>=21) &&  (value39<22)){console.log("value39 : 21-22 : " +value39); device.deviceStatus='bar_color_T22'}
	else if ((value39>=20) &&  (value39<21)){console.log("value39 : 20-21 : " +value39); device.deviceStatus='bar_color_T21'}
	else if ((value39>=19) &&  (value39<20)){console.log("value39 : 19-20 : " +value39); device.deviceStatus='bar_color_T29'}
	else if ((value39>=18) &&  (value39<19)){console.log("value39 : 18-19 : " +value39); device.deviceStatus='bar_color_T19'}
	else if ((value39>=17) &&  (value39<18)){console.log("value39 : 17-18 : " +value39); device.deviceStatus='bar_color_T18'}
	else if ((value39>=16) &&  (value39<17)){console.log("value39 : 16-17 : " +value39); device.deviceStatus='bar_color_T17'}
	else if ((value39>=15) &&  (value39<16)){console.log("value39 : 15-16 : " +value39); device.deviceStatus='bar_color_T16'}
	else if ((value39>=14) &&  (value39<15)){console.log("value39 : 14-15 : " +value39); device.deviceStatus='bar_color_T15'}
	else if ((value39>=13) &&  (value39<14)){console.log("value39 : 13-14 : " +value39); device.deviceStatus='bar_color_T14'}
	else if ((value39>=12) &&  (value39<13)){console.log("value39 : 12-13 : " +value39); device.deviceStatus='bar_color_T13'}
	else if ((value39>=11) &&  (value39<12)){console.log("value39 : 11-12 : " +value39); device.deviceStatus='bar_color_T12'}
	else if ((value39>=10) &&  (value39<11)){console.log("value39 : 10-11 : " +value39); device.deviceStatus='bar_color_T11'}
	else if ((value39>=9) &&  (value39<10)) {console.log("value39 :  9-10 : " +value39); device.deviceStatus='bar_color_T10'}
	else if ((value39>=8) &&  (value39<9))  {console.log("value39 :  8-9 : " +value39);  device.deviceStatus='bar_color_T9'}
	else if ((value39>=7) &&  (value39<8))  {console.log("value39 : 7-8 : " +value39);   device.deviceStatus='bar_color_T8'}
	else if ((value39>=6) &&  (value39<7))  {console.log("value39 : 6-7 : " +value39);   device.deviceStatus='bar_color_T7'}
	else if ((value39>=5) &&  (value39<6))  {console.log("value39 : 5-6 : " +value39);   device.deviceStatus='bar_color_T6'}
	else if ((value39>=4) &&  (value39<5))  {console.log("value39 : 4-5 : " +value39);   device.deviceStatus='bar_color_T5'}
	else if ((value39>=3) &&  (value39<4))  {console.log("value39 : 3-4 : " +value39);   device.deviceStatus='bar_color_T4'}
	else if ((value39>=2) &&  (value39<3))  {console.log("value39 : 2-3 : " +value39);   device.deviceStatus='bar_color_T3'}
	else if ((value39>=1) &&  (value39<2))  {console.log("value39 : 1-2 : " +value39);   device.deviceStatus='bar_color_T2'}
	else if ((value39>0) &&  (value39<1))   {console.log("value39 : 0-1 : " +value39);   device.deviceStatus='bar_color_T1'}
	else if (value39=0) {console.log("value39 : =0 : " +value39);   device.deviceStatus='bar_color_T0'}
	else if (value39<0) {console.log("value39 : <0 : " +value39);   device.deviceStatus='bar_color_T00'}
	//Potager
	if (device.idx==40)  {console.log('hook for device 40'); var value40=parseFloat(device.Data);
	if 	   (value40>=35) {console.log("value40 : >=35 : " +value40); device.deviceStatus='bar_color_T35'}
	else if ((value40>=34) &&  (value40<35)){console.log("value40 : 34-35 : " +value40); device.deviceStatus='bar_color_T35'}
	else if ((value40>=33) &&  (value40<34)){console.log("value40 : 33-34 : " +value40); device.deviceStatus='bar_color_T34'}
	else if ((value40>=32) &&  (value40<33)){console.log("value40 : 32-33 : " +value40); device.deviceStatus='bar_color_T33'}
	else if ((value40>=31) &&  (value40<32)){console.log("value40 : 31-32 : " +value40); device.deviceStatus='bar_color_T32'}
	else if ((value40>=30) &&  (value40<31)){console.log("value40 : 30-31 : " +value40); device.deviceStatus='bar_color_T31'}
	else if ((value40>=29) &&  (value40<30)){console.log("value40 : 29-30 : " +value40); device.deviceStatus='bar_color_T30'}
	else if ((value40>=28) &&  (value40<29)){console.log("value40 : 28-29 : " +value40); device.deviceStatus='bar_color_T29'}
	else if ((value40>=27) &&  (value40<28)){console.log("value40 : 27-28 : " +value40); device.deviceStatus='bar_color_T28'}
	else if ((value40>=26) &&  (value40<27)){console.log("value40 : 26-27 : " +value40); device.deviceStatus='bar_color_T27'}
	else if ((value40>=25) &&  (value40<26)){console.log("value40 : 25-26 : " +value40); device.deviceStatus='bar_color_T26'}
	else if ((value40>=24) &&  (value40<25)){console.log("value40 : 24-25 : " +value40); device.deviceStatus='bar_color_T25'}
	else if ((value40>=23) &&  (value40<24)){console.log("value40 : 23-24 : " +value40); device.deviceStatus='bar_color_T24'}
	else if ((value40>=22) &&  (value40<23)){console.log("value40 : 22-23 : " +value40); device.deviceStatus='bar_color_T23'}
	else if ((value40>=21) &&  (value40<22)){console.log("value40 : 21-22 : " +value40); device.deviceStatus='bar_color_T22'}
	else if ((value40>=20) &&  (value40<21)){console.log("value40 : 20-21 : " +value40); device.deviceStatus='bar_color_T21'}
	else if ((value40>=19) &&  (value40<20)){console.log("value40 : 19-20 : " +value40); device.deviceStatus='bar_color_T29'}
	else if ((value40>=18) &&  (value40<19)){console.log("value40 : 18-19 : " +value40); device.deviceStatus='bar_color_T19'}
	else if ((value40>=17) &&  (value40<18)){console.log("value40 : 17-18 : " +value40); device.deviceStatus='bar_color_T18'}
	else if ((value40>=16) &&  (value40<17)){console.log("value40 : 16-17 : " +value40); device.deviceStatus='bar_color_T17'}
	else if ((value40>=15) &&  (value40<16)){console.log("value40 : 15-16 : " +value40); device.deviceStatus='bar_color_T16'}
	else if ((value40>=14) &&  (value40<15)){console.log("value40 : 14-15 : " +value40); device.deviceStatus='bar_color_T15'}
	else if ((value40>=13) &&  (value40<14)){console.log("value40 : 13-14 : " +value40); device.deviceStatus='bar_color_T14'}
	else if ((value40>=12) &&  (value40<13)){console.log("value40 : 12-13 : " +value40); device.deviceStatus='bar_color_T13'}
	else if ((value40>=11) &&  (value40<12)){console.log("value40 : 11-12 : " +value40); device.deviceStatus='bar_color_T12'}
	else if ((value40>=10) &&  (value40<11)){console.log("value40 : 10-11 : " +value40); device.deviceStatus='bar_color_T11'}
	else if ((value40>=9) &&  (value40<10)) {console.log("value40 :  9-10 : " +value40); device.deviceStatus='bar_color_T10'}
	else if ((value40>=8) &&  (value40<9))  {console.log("value40 :  8-9 : " +value40);  device.deviceStatus='bar_color_T9'}
	else if ((value40>=7) &&  (value40<8))  {console.log("value40 : 7-8 : " +value40);   device.deviceStatus='bar_color_T8'}
	else if ((value40>=6) &&  (value40<7))  {console.log("value40 : 6-7 : " +value40);   device.deviceStatus='bar_color_T7'}
	else if ((value40>=5) &&  (value40<6))  {console.log("value40 : 5-6 : " +value40);   device.deviceStatus='bar_color_T6'}
	else if ((value40>=4) &&  (value40<5))  {console.log("value40 : 4-5 : " +value40);   device.deviceStatus='bar_color_T5'}
	else if ((value40>=3) &&  (value40<4))  {console.log("value40 : 3-4 : " +value40);   device.deviceStatus='bar_color_T4'}
	else if ((value40>=2) &&  (value40<3))  {console.log("value40 : 2-3 : " +value40);   device.deviceStatus='bar_color_T3'}
	else if ((value40>=1) &&  (value40<2))  {console.log("value40 : 1-2 : " +value40);   device.deviceStatus='bar_color_T2'}
	else if ((value40>0) &&  (value40<1))   {console.log("value40 : 0-1 : " +value40);   device.deviceStatus='bar_color_T1'}
	else if (value40=0) {console.log("value40 : =0 : " +value40);   device.deviceStatus='bar_color_T0'}
	else if (value40<0) {console.log("value40 : <0 : " +value40);   device.deviceStatus='bar_color_T00'}
Doudy
Post by Doudy »
Since version 3.8.9 the color management is not the same than before!
HansieNL
Post by HansieNL »
Have you seen the change in beta 3.8.8?
splitdial
Normally the dial ring color will color from the 0 value to the actual value, which can be positive or negative. Set this parameter to false to start coloring the dial ring from the minimum value, also for a negative minimum value.
Can you add splitdial: false to your dials and see if that fixes your problem?
Blah blah blah
Lokonli
Post by Lokonli »
Doudy wrote: Thursday 23 December 2021 15:29 Hello,
I think the CSS specificity is insufficient. I'll check how fix that.
Doudy
Post by Doudy »
Lokonli wrote: Thursday 23 December 2021 23:20 I think the CSS specificity is insufficient. I'll check how fix that.
Lokonli
Post by Lokonli »
Doudy wrote: Friday 24 December 2021 7:35
I've made a little update. If you update to the latest version, then your styling should work if you replace border-color with color:
.bar_color_T35 .primary, .bar_color_T35 .secondary {color: #FF0000 !important;}
You can shorten it by using the following:
.bar_color_T35 .slice {color: #FF0000 !important;}
This will change the ring coloring, independent of primary (above setpoint), secondary (below setpoint), positive, negative labeling.
Doudy
Post by Doudy »
First my best wishes :)
:arrow:
I made a git pull
Then I made the adaptations : .bar_color_T35 .slice {color: #FF0000 !important;} etc...
And the result is correct :
