switch the wrong switch id
hestia
Domoticz version: 2022.1
Post by hestia »
2 devices with different id but same name
     logging =   {   level   =  domoticz.LOG_DEBUG, },
		devices = {205},
	execute = function(dz, triggeredItem)
	    dz.devices(1987).switchOn()
before
Screenshot 2021-08-27 200635.png (12.58 KiB) Viewed 212 times
after
Screenshot 2021-08-27 200741.png (14.77 KiB) Viewed 212 times
Domoticz version: 2025.1
Re: switch the wrong switch id
For some reason dzVents does not like the same names for different devices. It is a known issue. Easy fix is to rename 1 :-)
hestia
Post by hestia »
ok, but strange when you only use id in the script!
"For some reason" it is because inside the names are used sometimes instead of the id
"known issue" not for me ;-)
"Easy fix" yes after the diagnostic (1 hour) because I didn't jump on that conclusion immediately
I follow the forum a little bit and on the zwave2mqtt topic people are moving a lot of devices from OZW to zwave2mqtt having the same issues with double device names in dzVents. I must admit that your use case did not occur there.
As @waaren has sadly fallen away from us I hope someone can step up and fix this kind of dzVents issues.
hestia
Post by hestia »
Yes, bad news for waaren :-(
The duplicated names are not the fault of zwave2mqtt, but mine.
zwave2mqtt initiated the devices with unique names, but I didn't like them!
I renamed some of them manually with temporary names to better understand the devices, and so I've set lots of duplicated!
I need to change them...
