Dashticz-Dial-Wind Speed-Min-Max
Doudy
Post by Doudy »
Here is my block wind:
blocks['wind'] = {
	idx: 43,
	title: 'Vitesse-Vent',  // Vitesse vent
	type: 'dial',
	color: '#57c4d6',
	min: 0,
	max: 100,
	values: [
			value: 'Speed',
			addClass: 'bigwind',
			decimals: 1,
			unit: ' Km/h',
	setpoint: 0,
	offset: 180,
	width: 2,
	showring: true,
	showunit: true,
	shownumbers: true,
	last_update: true,
	showvalue: false,
Width min: 0 and max: 100
Yet the display does not adapt
But Min and max is always between 0 and 360
A idea ?
HansieNL
Re: Dashticz-Dial-Wind Speed-Min-Max
Post by HansieNL »
See manual of wind dial:
This dial has a 360 degree range (like a compass). The wind direction can be set to point to where the wind is blowing from or to, by using the new "offset" parameter. Below I have set the dial to point to which direction the wind is blowing...
Blah blah blah
Doudy
Post by Doudy »
HansieNL wrote: Monday 09 August 2021 17:43 See manual of wind dial:
YES, I understood that.
My question was to know if it was possible to modify the scale and limit it between 0 and 100 for example.
For the wind speed 360 km/h seems a bit much to me ...
HansieNL
Post by HansieNL »
360 is for the wind direction like a compass not the wind speed. If you can’t change it, it looks like it’s fixed.
Maybe @Lokonli can give us the right answer when he is back online.
Blah blah blah
Doudy
Post by Doudy »
HansieNL wrote: Tuesday 10 August 2021 18:14 Maybe @Lokonli can give us the right answer when he is back online.
rolandtwilt
Post by rolandtwilt »
just a question out of my own interest (because you are much further ahead than me) where do you measure the wind?
Via an online weatherstation and an API or do you really have an anemometer in your garden or balcony?
I would like the the device in my garden, but it is not easy to find an anemometer unless you go for a weather station with Wifi, but that costs 150 euros
Doudy
Post by Doudy »
I have a "Renkforce WH2600 Wireless digital weather station"
Lokonli
Post by Lokonli »
HansieNL wrote: Tuesday 10 August 2021 18:14 360 is for the wind direction like a compass not the wind speed. If you can’t change it, it looks like it’s fixed.
For a wind device the dial indeed indicates the wind direction.
Currently this can't be changed.
I'll add it to the request list to make this configurable via a block parameter.
Doudy
Post by Doudy »
Lokonli wrote: Friday 13 August 2021 17:06 I'll add it to the request list to make this configurable via a block parameter.
rolandtwilt
Doudy wrote: Friday 13 August 2021 8:18 Hello,
thanks for your comment!
That's quite an expensive joke, at least for me
Doudy
Post by Doudy »
Have you ever had the time to look at this request?
Lokonli
Post by Lokonli »
Doudy wrote: Wednesday 08 December 2021 8:45
No, not really. I've to do some maintenance on the dial code first.
But please post a message in the 'next round' topic of @HansieNL:
viewtopic.php?f=67&t=37546
We'll manage feature requests from there.
Lokonli
Post by Lokonli »
Doudy wrote: Monday 09 August 2021 11:43 Hello,
blocks['wind'] = {
	idx: 43,
	type: 'dial',
	color: '#57c4d6',
	min: 0,
	max: 100,
	values: [
			value: 'Speed',
			decimals: 1,
			unit: ' Km/h',
	setpoint: 0,
	offset: 180,
	width: 2,
	showring: true,
	showunit: true,
	shownumbers: true,
	last_update: true,
	showvalue: false,
A idea ?
Try latest beta.
As an example, use the following block definition:
blocks['wind'] = {
    idx: 43,
    type: 'dial',
    subtype: 'windspeed',
    shownumbers: true,
[/code]
Doudy
Post by Doudy »
I do :
~/dashticz $ git pull
and
I tried following :
blocks['wind'] = {
    idx: 43,
    type: 'dial',
    shownumbers: true,
but not the expected result :
Lokonli
Post by Lokonli »
Your max value is 110, which is strange...
Further, title is not correct: Vitesse-Vent in block, and Vitesse du Vent on Dashboard.
Can you double check that you only have one blocks['wind'] definition in CONFIG.js,
and that you use 'wind' in your column?
Can you post the Domoticz device json output:
http://domoticz ip:port/json.htm?type=devices&rid=43
Doudy
Post by Doudy »
:oops:
It's my fault my very big fault
Lokonli wrote: Thursday 03 March 2022 15:04 Can you double check that you only have one blocks['wind'] definition in CONFIG.js,
Indeed there was a second block !
I'm trying to display the gust speed, but it doesn't seem to work !
blocks['wind2'] = {
    idx: 43,
    title: 'Rafale-Vent',  // Rafale vent
    type: 'dial',
    subtype: 'gustspeed',
    shownumbers: true,
	min: 0,
	max: 130,
Thank you for your help
Lokonli
Post by Lokonli »
Doudy wrote: Friday 04 March 2022 8:16 :oops:
blocks['wind2'] = {
    idx: 43,
    type: 'dial',
    shownumbers: true,
	min: 0,
	max: 130,
No, that has not been implemented.
I can add gustspeed, but let's think of a more generic solution, that also has value for other dial types.
Doudy
Post by Doudy »
Lokonli wrote: Friday 04 March 2022 8:25 I can add gustspeed, but let's think of a more generic solution, that also has value for other dial types.
Lokonli
Post by Lokonli »
Try latest beta with:
blocks['wind2'] = {
    idx: 43,
    type: 'dial',
    subtype: 'windgust',
Doudy
Post by Doudy »
It's OK
