Moderators: leecollings , htilburgs , robgeerts
Doudy
Posts: 246 Joined: Tuesday 09 August 2016 9:09
Post
by Doudy » Monday 09 August 2021 11:43
Here is my block wind:
blocks['wind'] = {
idx: 43,
title: 'Vitesse-Vent', // Vitesse vent
type: 'dial',
color: '#57c4d6',
min: 0,
max: 100,
values: [
value: 'Speed',
addClass: 'bigwind',
decimals: 1,
unit: ' Km/h',
setpoint: 0,
offset: 180,
width: 2,
showring: true,
showunit: true,
shownumbers: true,
last_update: true,
showvalue: false,
Width min: 0 and max: 100
Yet the display does not adapt
But Min and max is always between 0 and 360
A idea ?
HansieNL
Posts: 969 Joined: Monday 28 September 2015 15:13
Post
by HansieNL » Monday 09 August 2021 17:43
See manual of wind dial:
This dial has a 360 degree range (like a compass). The wind direction can be set to point to where the wind is blowing from or to, by using the new "offset" parameter. Below I have set the dial to point to which direction the wind is blowing...
Blah blah blah
Doudy
Post
by Doudy » Tuesday 10 August 2021 7:49
HansieNL wrote: Monday 09 August 2021 17:43
YES, I understood that.
My question was to know if it was possible to modify the scale and limit it between 0 and 100 for example.
For the wind speed 360 km/h seems a bit much to me ...
HansieNL
Post
by HansieNL » Tuesday 10 August 2021 18:14
360 is for the wind direction like a compass not the wind speed. If you can’t change it, it looks like it’s fixed.
Maybe @Lokonli can give us the right answer when he is back online.
Blah blah blah
Doudy
Post
by Doudy » Friday 13 August 2021 7:44
HansieNL wrote: Tuesday 10 August 2021 18:14
rolandtwilt
Posts: 74 Joined: Monday 05 October 2020 18:55
Post
by rolandtwilt » Friday 13 August 2021 8:12
just a question out of my own interest (because you are much further ahead than me) where do you measure the wind?
Via an online weatherstation and an API or do you really have an anemometer in your garden or balcony?
I would like the the device in my garden, but it is not easy to find an anemometer unless you go for a weather station with Wifi, but that costs 150 euros
Doudy
Post
by Doudy » Friday 13 August 2021 8:18
I have a "Renkforce WH2600 Wireless digital weather station"
Lokonli
Posts: 2292 Joined: Monday 29 August 2016 22:40
Post
by Lokonli » Friday 13 August 2021 17:06
For a wind device the dial indeed indicates the wind direction.
Currently this can't be changed.
I'll add it to the request list to make this configurable via a block parameter.
Doudy
Post
by Doudy » Saturday 14 August 2021 8:42
Lokonli wrote: Friday 13 August 2021 17:06
rolandtwilt
Post
by rolandtwilt » Wednesday 25 August 2021 10:27
Doudy wrote: Friday 13 August 2021 8:18
thanks for your comment!
That's quite an expensive joke, at least for me
Doudy
Post
by Doudy » Wednesday 08 December 2021 8:45
Have you ever had the time to look at this request?
Lokonli
Post
by Lokonli » Wednesday 08 December 2021 8:59
Doudy wrote: Wednesday 08 December 2021 8:45
No, not really. I've to do some maintenance on the dial code first.
But please post a message in the 'next round' topic of @HansieNL:
viewtopic.php?f=67&t=37546
We'll manage feature requests from there.
Lokonli
Post
by Lokonli » Wednesday 02 March 2022 21:28
Doudy wrote: Monday 09 August 2021 11:43
blocks['wind'] = {
idx: 43,
type: 'dial',
color: '#57c4d6',
min: 0,
max: 100,
values: [
value: 'Speed',
decimals: 1,
unit: ' Km/h',
setpoint: 0,
offset: 180,
width: 2,
showring: true,
showunit: true,
shownumbers: true,
last_update: true,
showvalue: false,
A idea ?
Try latest beta.
As an example, use the following block definition:
blocks['wind'] = {
idx: 43,
type: 'dial',
subtype: 'windspeed',
shownumbers: true,
[/code]
Doudy
Post
by Doudy » Thursday 03 March 2022 14:40
I do :
and
I tried following :
blocks['wind'] = {
idx: 43,
type: 'dial',
shownumbers: true,
but not the expected result :
Lokonli
Post
by Lokonli » Thursday 03 March 2022 15:04
Your max value is 110, which is strange...
Further, title is not correct: Vitesse-Vent in block, and Vitesse du Vent on Dashboard.
Can you double check that you only have one blocks['wind'] definition in CONFIG.js,
and that you use 'wind' in your column?
Can you post the Domoticz device json output:
http://domoticz ip:port/json.htm?type=devices&rid=43
Doudy
Post
by Doudy » Friday 04 March 2022 8:16
It's my fault my very big fault
Lokonli wrote: Thursday 03 March 2022 15:04
Indeed there was a second block !
I'm trying to display the gust speed, but it doesn't seem to work !
blocks['wind2'] = {
idx: 43,
title: 'Rafale-Vent', // Rafale vent
type: 'dial',
subtype: 'gustspeed',
shownumbers: true,
min: 0,
max: 130,
Thank you for your help
Lokonli
Post
by Lokonli » Friday 04 March 2022 8:25
Doudy wrote: Friday 04 March 2022 8:16
blocks['wind2'] = {
idx: 43,
type: 'dial',
shownumbers: true,
min: 0,
max: 130,
No, that has not been implemented.
I can add gustspeed, but let's think of a more generic solution, that also has value for other dial types.
Doudy
Post
by Doudy » Friday 04 March 2022 8:30
Lokonli wrote: Friday 04 March 2022 8:25
Lokonli
Post
by Lokonli » Sunday 06 March 2022 8:24
Try latest beta with:
blocks['wind2'] = {
idx: 43,
type: 'dial',
subtype: 'windgust',
Doudy
Post
by Doudy » Sunday 06 March 2022 10:07
