WhToday error
hclardij
WhToday error
Post by hclardij »
I am new to programming and started with a little script to add the power generation of my 2 SMA inverters. Somehow I see something weird that I cannot explan. Please help.
First I created a 'dummy', sensor type 'electric (instant + counter)'
Then created this script:
timer = { 'every 1 minutes' }
local SolarPowerE = domoticz.devices(1) -- Power Erker
local SolarPowerG = domoticz.devices(3) -- Power Garage
local SolarPowerT = domoticz.devices(5) -- Total Solar Power
SolarPowerT.updateElectricity(
SolarPowerE.WhActual + SolarPowerG.WhActual,
SolarPowerE.WhToday + SolarPowerG.WhToday
Where SolarPowerT is the sum of my 2 generated powers of the inverters.
What I see is the following: SolarPowerT. WhActual is displaying the right value; SolarPowerT.WhToday starts with the negative value of what has been produced the day before. So if I have generated 35kWh on monday, it starts at tuesday 0.00 hours with -35kWh and then slowly ramps up.
Both the Inverters start the day with 0 so the total should be 0 too.
What am I overlooking here?
Thanks in advance !
Domoticz version: 2025.1
Re: WhToday error
The counter value should be the total counter until now, like what you read on the display of your electricity meter.
So today 35
Tomorrow 35+30.
Etc
So you should combine the .WhTotal values instead of WhToday and put that in your combined dummy device.
Domoticz will do the today calculation for you.
Derik
Re: WhToday error
Post by Derik »
Like to have this script also..
I do also have multiple inverters..
hclardij
Re: WhToday error
Post by hclardij »
That could be an explanation although that would be agains what I read in the manual and that is 100% not what I see;
Every night the counter starts at a negative number This morning the value started at -37.4 kWh or so... During the day the numbers add up nicely,...but it always starts with the wrong number at midnight.
hclardij
Re: WhToday error
Post by hclardij »
I see what you mean with the counter; I don't see why I start with the negative still. I tried with the WhToday but that is for the moment displaying the wrong value; I need to check what happens after midnight
Re: WhToday error
This script should work
	SolarPowerT.updateElectricity(SolarPowerE.WhActual + SolarPowerG.WhActual, SolarPowerE.WhTotal + SolarPowerG.WhTotal)
hclardij
Re: WhToday error
Post by hclardij »
I have tried that; I see a value but not the value that I want to see. This is displaying the total kWh that has been generated in its lifetime for both inverters.
Lets take 1 stap back to explain what I want to have displayed: I want the actual generated power and the total generated power for that day.
The value should be set to 0 at the beginning of the day.
Each inverter is giving those values individually, but I want to have the sum of both inverters.
I did a little test and created a second dummy sensor SolarPowerTT; Furthermore I set the value for the 2nd variable in the function to 0 instead of the sum of 2 other values.
local SolarPowerT = domoticz.devices(5) -- Total Solar Power Actual
local SolarPowerTT = domoticz.devices(6) -- Total Solar Power Today
SolarPowerT.updateElectricity(SolarPowerE.actualWatt + SolarPowerG.actualWatt, 0)
SolarPowerTT.updateElectricity(SolarPowerE.WhToday + SolarPowerG.WhToday, 0)
This is the output:
So the SolarTotalToday sensor is working as it is displaying the right value.
The 'Today' value in the SolarTotal sensor is constant at minus 37.441 kWh . So by the looks it starts at -37k and then adds 0 everytime the script runs. Hence the steady -37441.
I think the electricity function in not appropriate for what I am looking for; I just need 2 values and no counter.
NB: This is a test setup with nothing else attached to it.
Thanks for your help!
Re: WhToday error
hclardij wrote: Monday 19 July 2021 15:49 Hi,
This is because it is the first time you did the calculation. If you keep on sending the data it will behave exactly the same as your normal 2 single solar panel counters. So you have to be patient...... keep it running for a couple of days.
hclardij
Re: WhToday error
Post by hclardij »
Ok, I'll do that ! Thanks !
hclardij
Re: WhToday error
Post by hclardij »
You are right,..it works now.!!
Thanks a lot!
