Hi everyone,
I launched myself into a home automation project in which I wanted to integrate a lux sensor to control the lights intensity via Domoticz.
So I flashed an ESP8266 with ESPEasy and connected a GL5528 like so : wiring 3,3V to A0 through a 1KOhm resistor and the GL5528 from A0 to GND.
When I look at the web interface (configured as Analog Input : Internal), I got a steady value of 65535. Whatever I do, it's not moving.
I first thought it was the resistor which was too low, so I changed it for a 4,7K then a 47K resistor without sucess. Still the same steady value ... I also replaced the GL5528 just in case.
Then I red on the wiki that ESP8266 NodeMCU already had a pullup/down resistor, so I replaced the 47K with a wire. Still, nothing has changed !
I'm coming out of ideas, so if you have any informations that could help me troubleshoot this !
Thank you in advance
Need help with an ESP8266 and a photocell
- erem
- Domoticz version: 2021.1
Re: Need help with an ESP8266 and a photocell
you will most likely have better response if you ask this on the espeasy forum
here: https://www.letscontrolit.com/forum/
Regards,
Rob
Rob
- jvdz
- Domoticz version: 4.107
Shouldn't that be wired like shown in this example?:
https://www.hackster.io/gary-watts/esp8 ... schematics
Jos
Jos
- Treve
- Domoticz version: v4.11474
I build a LUX sensor with ESP8266 (standard software ) and Lux sensor BH1750, no use of resistors.
ESP8266 send his data to Domoticz, with a Blockly I manage the darkness in the living room. It works flawlessly.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Treve
This was the test setup.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- jvdz
A photocell is something different from the BH1750, which works quite different. The photocell is simply a resistor which varies based on the light. That is why you need the 3.3v - LDR - a0 pin - fixed resistor - 0. The a0 wil get a variable Volt level based on the resistance of the LDR.
Agree that the BH1750 works "better" but I have both and it should also work when no accuracy is required.
Jos
Jos
- Treve
Hi Jos, I know the difference. I’m using the LDR as well as shown. It allows the sunscreen to go out.
The topic starter was talking about lux, so I responded with my build to show it can be very simpel, accurate and cheap
With regards,
Evert
With regards,
Evert
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
Yup, it's what I did, sorry, I messed myself when writing ...jvdz wrote: ↑Sunday 23 May 2021 20:39 Shouldn't that be wired like shown in this example?:
Jos
Thanks for the link of the forum, I tried to post on the ESP reddit but got insta moderated for no reasonserem wrote: ↑Sunday 23 May 2021 20:06 you will most likely have better response if you ask this on the espeasy forum
I originally bought photocells to reduce cost at maximum since I already had resistors, but now I'm considering buying an I2C BH1750 !
I'll try posting on the ESP forum, I don't like to stay on a unexplained failure ...
Thank you for the quick answers
I'm back with an answer from the ESP forum. Apparently, if the firmware contains VCC in its name, then the A0 input doesn't work quite fine. I changed mine and it's now working just perfect with a 10KOhm resistor. (ESP_Easy_mega_20210503_test_A_ESP8266_4M1M.bin : name of the firmware used)
