Need help with an ESP8266 and a photocell
Everything about esp8266 and more.
Morrine
Post by Morrine »
Hi everyone,
I launched myself into a home automation project in which I wanted to integrate a lux sensor to control the lights intensity via Domoticz.
So I flashed an ESP8266 with ESPEasy and connected a GL5528 like so : wiring 3,3V to A0 through a 1KOhm resistor and the GL5528 from A0 to GND.
When I look at the web interface (configured as Analog Input : Internal), I got a steady value of 65535. Whatever I do, it's not moving.
I first thought it was the resistor which was too low, so I changed it for a 4,7K then a 47K resistor without sucess. Still the same steady value ... I also replaced the GL5528 just in case.
Then I red on the wiki that ESP8266 NodeMCU already had a pullup/down resistor, so I replaced the 47K with a wire. Still, nothing has changed !
I'm coming out of ideas, so if you have any informations that could help me troubleshoot this !
Thank you in advance
erem
Domoticz version: 2021.1
Re: Need help with an ESP8266 and a photocell
Post by erem »
you will most likely have better response if you ask this on the espeasy forum
here: https://www.letscontrolit.com/forum/
Regards,
Rob
jvdz
Domoticz version: 4.107
Post by jvdz »
Shouldn't that be wired like shown in this example?:
https://www.hackster.io/gary-watts/esp8 ... schematics
Jos
Treve
Domoticz version: v4.11474
Post by Treve »
I build a LUX sensor with ESP8266 (standard software ) and Lux sensor BH1750, no use of resistors.
ESP8266 send his data to Domoticz, with a Blockly I manage the darkness in the living room. It works flawlessly.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
Treve
Post by Treve »
This was the test setup.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
jvdz
Post by jvdz »
A photocell is something different from the BH1750, which works quite different. The photocell is simply a resistor which varies based on the light. That is why you need the 3.3v - LDR - a0 pin - fixed resistor - 0. The a0 wil get a variable Volt level based on the resistance of the LDR. :)
Agree that the BH1750 works "better" but I have both and it should also work when no accuracy is required.
Jos
Treve
Post by Treve »
Hi Jos, I know the difference. I’m using the LDR as well as shown. It allows the sunscreen to go out.
The topic starter was talking about lux, so I responded with my build to show it can be very simpel, accurate and cheap
With regards,
Evert
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
Morrine
Post by Morrine »
jvdz wrote: Sunday 23 May 2021 20:39 Shouldn't that be wired like shown in this example?:
Jos
Yup, it's what I did, sorry, I messed myself when writing ...
erem wrote: Sunday 23 May 2021 20:06 you will most likely have better response if you ask this on the espeasy forum
Thanks for the link of the forum, I tried to post on the ESP reddit but got insta moderated for no reasons :(
I originally bought photocells to reduce cost at maximum since I already had resistors, but now I'm considering buying an I2C BH1750 !
I'll try posting on the ESP forum, I don't like to stay on a unexplained failure ...
Thank you for the quick answers :)
Morrine
Post by Morrine »
I'm back with an answer from the ESP forum. Apparently, if the firmware contains VCC in its name, then the A0 input doesn't work quite fine. I changed mine and it's now working just perfect with a 10KOhm resistor. (ESP_Easy_mega_20210503_test_A_ESP8266_4M1M.bin : name of the firmware used)
