I updated domoticz with the version 2021.1 and since Dashticz doesn't work.
Is anybody in the same case ?
Thank you
Update domoticz v2021.1 and Dashticz doesn't work
- HansieNL
Re: Update domoticz v2021.1 and Dashticz doesn't work
Can you give some more information?
- What version of Dashticz are you using
- Did you use auto or manual install Dasticz
- Where did you install Dashticz
Blah blah blah
Matthias
I use Dashitcz v3.7 master.
I installed on my rpi 3b+.
I don't remenber which method i use to install. It was a long time.
Lokonli
I've tested Dashticz with Domoticz v2021.1. Everything seems to work without issues.
If you've updated Domoticz:
Check that you've filled in your username/password correctly in Domoticz, and that you use the same in Dashticz,
or that you whitelisted your LAN in Domoticz->Settings->Local Networks.
If you still have problems, open DevTools (F12), refresh Dashticz, and look for errors in the Network tab or in the Console tab.
Matthias
Ok thank you for advices.
It’s too late in France. I will look this tomorrow.
Matthias
[SOLVED] : Update domoticz v2021.1 and Dashticz doesn't work
You were right.
This is the whitelist in the domoticz settings.
The update always changes me a ";" in "," which prevents access.
Thank you for your help.
