Update domoticz v2021.1 and Dashticz doesn't work
Matthias
Post by Matthias »
I updated domoticz with the version 2021.1 and since Dashticz doesn't work.
Is anybody in the same case ?
Thank you
HansieNL
Re: Update domoticz v2021.1 and Dashticz doesn't work
Post by HansieNL »
Can you give some more information?
- What version of Dashticz are you using
- Did you use auto or manual install Dasticz
- Where did you install Dashticz
Blah blah blah
Matthias
Post by Matthias »
I use Dashitcz v3.7 master.
I installed on my rpi 3b+.
I don't remenber which method i use to install. It was a long time.
Lokonli
Post by Lokonli »
I've tested Dashticz with Domoticz v2021.1. Everything seems to work without issues.
If you've updated Domoticz:
Check that you've filled in your username/password correctly in Domoticz, and that you use the same in Dashticz,
or that you whitelisted your LAN in Domoticz->Settings->Local Networks.
If you still have problems, open DevTools (F12), refresh Dashticz, and look for errors in the Network tab or in the Console tab.
Matthias
Post by Matthias »
Ok thank you for advices.
It’s too late in France. I will look this tomorrow.
Matthias
[SOLVED] : Update domoticz v2021.1 and Dashticz doesn't work
Post by Matthias »
You were right.
This is the whitelist in the domoticz settings.
The update always changes me a ";" in "," which prevents access.
Thank you for your help.
