[SOLVED] Weather - does not work correctly with theme white
Posted: Sunday 25 April 2021 19:19
by Renber
Since the last update (3.8.2) the weather layout 0 and 1 remains on the 'default' theme while 'white' is selected.
Layout 2 has the right theme but is much bigger than before, it's not very pretty.
Thank you
Re: Weather - does not work correctly with theme white
Posted: Sunday 25 April 2021 21:28
by Lokonli
Renber wrote:Hello,
Thank you
I've never tried the theming, but I'll check.
To reduce the size you can set the width parameter or the scale parameter.
Verstuurd vanaf mijn AC2003 met Tapatalk
Posted: Thursday 29 April 2021 18:19
by Lokonli
Renber wrote: Sunday 25 April 2021 19:19
Thank you
I've fixed the 'white' theme coloring for the weather blocks.
In the future the theming mechanisms need to be updated, but for now it works.
Posted: Thursday 29 April 2021 21:17
by Renber
Hello, I have tested it works. Thank you
There is still a problem: I put the "rounded corners" command in the css but the weather forecast is square.
A +
