Since the last update (3.8.2) the weather layout 0 and 1 remains on the 'default' theme while 'white' is selected.
Layout 2 has the right theme but is much bigger than before, it's not very pretty.
Thank you
[SOLVED] Weather - does not work correctly with theme white
Linux Debian 12 Server: Domoticz beta + Dashticz beta + Node-Red + Homebridge
Re: Weather - does not work correctly with theme white
I've never tried the theming, but I'll check.Renber wrote:Hello,
Thank you
To reduce the size you can set the width parameter or the scale parameter.
Verstuurd vanaf mijn AC2003 met Tapatalk
I've fixed the 'white' theme coloring for the weather blocks.
In the future the theming mechanisms need to be updated, but for now it works.
Hello, I have tested it works. Thank you
There is still a problem: I put the "rounded corners" command in the css but the weather forecast is square.
A +
A +
