Since the last update (3.8.2) the weather layout 0 and 1 remains on the 'default' theme while 'white' is selected.
Layout 2 has the right theme but is much bigger than before, it's not very pretty.
Thank you
[SOLVED] Weather - does not work correctly with theme white
Renber
Linux Debian 12 Server: Domoticz beta + Dashticz beta + Node-Red + Homebridge
Lokonli
Re: Weather - does not work correctly with theme white
I've never tried the theming, but I'll check.Renber wrote:Hello,
Thank you
To reduce the size you can set the width parameter or the scale parameter.
Verstuurd vanaf mijn AC2003 met Tapatalk
Lokonli
I've fixed the 'white' theme coloring for the weather blocks.Renber wrote: Sunday 25 April 2021 19:19 Hello,
Thank you
In the future the theming mechanisms need to be updated, but for now it works.
Renber
Hello, I have tested it works. Thank you
There is still a problem: I put the "rounded corners" command in the css but the weather forecast is square.
A +
A +
