Growatt shows minus value since update of domoticz
rick8245
Post by rick8245 »
Since the update of Domoticz last week, my Growatt Inverter shows a minus value instead of the correct value.
Does someone knows how to get back the correct value ?
thanks in advance
Rick
Domoticz version: 2025.1
Re: Growatt shows minus value since update of domoticz
Looks like viewtopic.php?f=6&t=36076 or viewtopic.php?f=6&t=35610 or viewtopic.php?f=14&t=35958
Solution: Change the script (or is it domoticz hardware plugin?) or change (edit button) on the device the daily energy read from "from device" to "computed".
rick8245
Post by rick8245 »
Thanks for the answer Waltervl,
Unfortunately none of the suggestiosn did not work out for me yet.
Any other ideas ??
Thanks in advance,
Rick
What hardware device/plugin or script are you using for Growatt?
rick8245
Post by rick8245 »
Hardware is dummy and for the device I followed this page (which is in Dutch)
but the commands may give you the needed info.
https://robothuis.nl/2020/01/13/zonnepa ... -domoticz/
Perhaps ask it in a remark on that page. Things have changed somewhat in these devices so that php script probably needs a modification.
rick8245
Post by rick8245 »
Thanks I will contact them.
sincze
Domoticz version: 2024.4
Post by sincze »
Please check you are using the latest version that has:
//$todaypower = (float)str_ireplace('kWh', '', $data['todayStr']);
$todaypower = (float)str_ireplace('kWh', '', $data['totalStr']);		// 18-04-2020
in it.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
rick8245
Post by rick8245 »
This line is in my .php script. So that must be ok
sincze
Post by sincze »
Let me check with my code then as currently not expecting issues.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
Post by rick8245 »
@Sincze, do you not have this problem ??
I include my script here
GW_php_script.txt
(10.08 KiB) Downloaded 80 times
sincze
Post by sincze »
Slight difference so it seems.
Mine has:
$data = json_decode($result, JSON_PRETTY_PRINT);
if(!empty($data['todayStr']) && !empty($data['totalValue'])) {
  $nowpower = (float)$data['powerValue'];
  $todaypower = (float)$data['todayValue'];	// kWH
  $allpower = (float)$data['totalValue'];		//   [totalStr] => 1505.4kWh	[totalValue] => 1505.4
  $allpower = $allpower*1000;					// Convert to Wh
  $str=( $nowpower.';'.$allpower ); // times 1000 to convert the 0.1kWh to 100 WattHour and to convert 2.1kWh to 2100 WattHour
  lg('Growatt Inverter: '. $nowpower.' for domoticz: '.$str);
  ud(DOMOTICZDEVICE,0,$str,'GrowattInverter: Generation updated');
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
Post by rick8245 »
Hi Sincze,
If I modify my old block with your block it looks like this:
curl_close($curl);
But....unfortunately the result is still the same.
Can you send me your whole script ?
rick8245
Post by rick8245 »
Now I see this value at today value : 3201.900
So this looks not OK. It should be 1.5 (it is cloudy outside)
sincze
Post by sincze »
Wait 24h hours it is the correction.
Look at the code change. :)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
Post by rick8245 »
ok , i will keep you informed
sincze
Post by sincze »
If you look at what changed in the code ;-) this will explain why you see the big value. (we went from daily to total generation)
Domoticz needed this 1 time correction, hence the -xx values every day.
Next day it will look like:
As you can see this is pretty much now ;-)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
Post by rick8245 »
@Sincze: Thanks for all your support.
It works like a charm again.
sincze
Post by sincze »
You are welcome. Maybe we should update GitHub as well. :) Pull request ???
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
Post by rick8245 »
I do not know how that works .
