Growatt shows minus value since update of domoticz
rick8245
Since the update of Domoticz last week, my Growatt Inverter shows a minus value instead of the correct value.
Does someone knows how to get back the correct value ?
thanks in advance
Rick
thanks in advance
Rick
- Domoticz version: 2025.1
Re: Growatt shows minus value since update of domoticz
Looks like viewtopic.php?f=6&t=36076 or viewtopic.php?f=6&t=35610 or viewtopic.php?f=14&t=35958
Solution: Change the script (or is it domoticz hardware plugin?) or change (edit button) on the device the daily energy read from "from device" to "computed".
rick8245
Thanks for the answer Waltervl,
Unfortunately none of the suggestiosn did not work out for me yet.
Any other ideas ??
Thanks in advance,
Rick
Any other ideas ??
Thanks in advance,
Rick
What hardware device/plugin or script are you using for Growatt?
rick8245
Hardware is dummy and for the device I followed this page (which is in Dutch)
but the commands may give you the needed info.
https://robothuis.nl/2020/01/13/zonnepa ... -domoticz/
Perhaps ask it in a remark on that page. Things have changed somewhat in these devices so that php script probably needs a modification.
rick8245
Thanks I will contact them.
- sincze
- Domoticz version: 2024.4
Please check you are using the latest version that has:
in it.
//$todaypower = (float)str_ireplace('kWh', '', $data['todayStr']);
$todaypower = (float)str_ireplace('kWh', '', $data['totalStr']); // 18-04-2020Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
This line is in my .php script. So that must be ok
- sincze
Let me check with my code then as currently not expecting issues.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
@Sincze, do you not have this problem ??
I include my script here
- GW_php_script.txt
- (10.08 KiB) Downloaded 79 times
- sincze
Slight difference so it seems.
Mine has:
Mine has:
$data = json_decode($result, JSON_PRETTY_PRINT);
if(!empty($data['todayStr']) && !empty($data['totalValue'])) {
$nowpower = (float)$data['powerValue'];
$todaypower = (float)$data['todayValue']; // kWH
$allpower = (float)$data['totalValue']; // [totalStr] => 1505.4kWh [totalValue] => 1505.4
$allpower = $allpower*1000; // Convert to Wh
$str=( $nowpower.';'.$allpower ); // times 1000 to convert the 0.1kWh to 100 WattHour and to convert 2.1kWh to 2100 WattHour
lg('Growatt Inverter: '. $nowpower.' for domoticz: '.$str);
ud(DOMOTICZDEVICE,0,$str,'GrowattInverter: Generation updated');
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
Hi Sincze,
If I modify my old block with your block it looks like this:
curl_close($curl);
But....unfortunately the result is still the same.
Can you send me your whole script ?
curl_close($curl);
rick8245
Now I see this value at today value : 3201.900
So this looks not OK. It should be 1.5 (it is cloudy outside)
- growaat_new.png (11.79 KiB) Viewed 2409 times
- sincze
Wait 24h hours it is the correction.
Look at the code change.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
ok , i will keep you informed
- sincze
If you look at what changed in the code
this will explain why you see the big value. (we went from daily to total generation)
Domoticz needed this 1 time correction, hence the -xx values every day.
Next day it will look like: As you can see this is pretty much now
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
@Sincze: Thanks for all your support.
It works like a charm again.
- Growatt_OK.png (18.71 KiB) Viewed 2390 times
- sincze
You are welcome. Maybe we should update GitHub as well.
Pull request ???
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
rick8245
I do not know how that works .
