Use of blinds percentage inverted in Smart Nora
FireWizard
Post by FireWizard »
Hello @delfisastre,
With respect to your question in viewtopic.php?f=69&t=27588&start=180.
Please find below the answer:
The flow looks as follows:
Change the configuration of the MQTT nodes, called "Domoticz Out" and "Domoticz In"
Change also the IDX number in the "Switch" node, so that it matches your IDX number (9), currently 11.
Change also the configuration of the Smart Nora node, so that it fits yours (currently "smartnora config")
For simplicity you will find the contents of the first "Function" ( Domoticz to Google Home) node below:
msg.topic = msg.payload.idx;
if (msg.payload.nvalue === 1) {
    msg.payload = {
        openPercent : 100
return msg;
else if (msg.payload.nvalue === 0) {
    msg.payload = {
        openPercent : 0
return msg;
else if (msg.payload.nvalue === 2) {
    msg.payload = {
        openPercent : msg.payload.svalue1
return msg;
else {return null}
The contents of the second "Function" ( Google Home to Domoticz) node you will find below:
var idx = parseInt(msg.topic);
if (msg.payload.openPercent === 100) {
 msg.payload = { "command": "switchlight", "idx": idx, "switchcmd": "On"};
else if (msg.payload.openPercent === 0) {
 msg.payload = { "command": "switchlight", "idx": idx, "switchcmd": "Off"};
 else {
 msg.payload = {"command": "switchlight", "idx": idx, "switchcmd": "Set Level", "level": msg.payload.openPercent};
return msg
Can you test these and report back?
PLease find the complete flow below:
[{"id":"e109e3fb.fb1b2","type":"tab","label":"Test","disabled":false,"info":""},{"id":"f8f35d1c.17aa48","type":"mqtt in","z":"e109e3fb.fb1b2","name":"Domoticz Out","topic":"domoticz/out","qos":"2","datatype":"json","broker":"f9f13036.e28b58","nl":false,"rap":false,"x":110,"y":380,"wires":[["b1e44280.bfcc98"]]},{"id":"b1e44280.bfcc98","type":"switch","z":"e109e3fb.fb1b2","name":"Filter Shutter Switch","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"11","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":320,"y":380,"wires":[["7e15f7f9.c65418"]]},{"id":"471ebff2.8f1778","type":"noraf-blinds","z":"e109e3fb.fb1b2","devicename":"Persiana comedor","roomhint":"Menjador","name":"Persiana comedor","passthru":false,"invert":false,"nora":"1c76c7bf.6c61e","topic":"9","x":770,"y":380,"wires":[["7bb24be6.735324"]]},{"id":"88a266be.046a2","type":"mqtt out","z":"e109e3fb.fb1b2","name":"Domoticz In","topic":"domoticz/in","qos":"2","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"f9f13036.e28b58","x":1210,"y":380,"wires":[]},{"id":"7e15f7f9.c65418","type":"function","z":"e109e3fb.fb1b2","name":"Function Shutter In","func":"msg.topic = msg.payload.idx;\n\nif (msg.payload.nvalue === 1) {\n    msg.payload = {\n        openPercent : 100\n    }\nreturn msg;    \n}\n\nelse if (msg.payload.nvalue === 0) {\n    msg.payload = {\n        openPercent : 0\n    }\nreturn msg;\n}\nelse if (msg.payload.nvalue === 2) {\n    msg.payload = {\n        openPercent : msg.payload.svalue1\n    }\nreturn msg;\n}\nelse {return null}","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":380,"wires":[["471ebff2.8f1778"]]},{"id":"7bb24be6.735324","type":"function","z":"e109e3fb.fb1b2","name":"Function Shutter Out","func":"var idx = parseInt(msg.topic);\n\nif (msg.payload.openPercent === 100) {\n msg.payload = { \"command\": \"switchlight\", \"idx\": idx, \"switchcmd\": \"On\"};\n }\nelse if (msg.payload.openPercent === 0) {\n msg.payload = { \"command\": \"switchlight\", \"idx\": idx, \"switchcmd\": \"Off\"};\n }\n else {\n msg.payload = {\"command\": \"switchlight\", \"idx\": idx, \"switchcmd\": \"Set Level\", \"level\": msg.payload.openPercent};\n }\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1000,"y":380,"wires":[["88a266be.046a2"]]},{"id":"f9f13036.e28b58","type":"mqtt-broker","name":"localhost","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"1c76c7bf.6c61e","type":"noraf-config","name":"smartnora config","group":"Test92","twofactor":"off","twofactorpin":"","localexecution":true,"structure":"Test"}]
delfisastre
Domoticz version: 2020.1
Re: Use of blinds percentage inverted in Smart Nora
Post by delfisastre »
THANK YOU!!!! finaly works! Blinds and Dimmers. :D
