I added DarkSky to the Hardware and within 5 or 10 minutes there should be some devices added to the devices tab.
All the info I setup is OK (like API key, Latitude, longitude) but the devices do NOT appear whatever i try.
What is wrong ??
Thanks in advance for your answers
DarksSky API Key OK but NO devices
- kiddigital
Re: DarksSky API Key OK but NO devices
Check the logs..
Not sure if Darksky still works as expected.
Otherwise try OpenWeatherMap (free registration for an API key).
rick8245
Darksy should work while it supports everything and also provided a api key.
The log file says:
2021-03-13 14:26:29.049 Error: Darksky: Error getting http data!.
I also tried OpenWahtermap but here it is the same problem.
As Location i have the latitud and longitude but tried the townname also.
Whatever i try i still also get here the same error
2021-03-13 14:23:46.339 Error: OpenWeatherMap: Error getting http data!
has it something to do with http data while the url is https ??
The log file says:
